(Topic ID: 255095)
Williams Diner Switch Issue
By toberlindacher
15 days ago
  • 7 posts
  • 2 Pinsiders participating
  • Latest reply 14 days ago by toberlindacher
#1 15 days ago
I have a Diner that has the shooter lane and the Ball Trough #2 that register together when either one is activated. I have continuity between the WHT-BLU and WHT-YEL circuit. I have looked very closely at the switch matrix and at the wiring. I have tested the diodes and installed a new shooter lane switch and diode. I can't seem to find the error. The symptom in the game is that when a ball is locked, the trough will eject two balls. Thanks for your help.
#2 15 days ago
Update: When I unplug the connector from the main pcb, the short goes away. Looks like I most likely have a board issue. Any ideas where to start looking?
#3 14 days ago
Update 2: The short goes away from the playfield switches when I unplug the connectors from the interconnect pcb. I think the short might be on that pcb or in a connector. I'm going to start plugging in connectors one by one until the short returns and that should give me some direction.
#4 14 days ago
The short is only present when I plug 2J18 which comes from the playfield switches to the interconnect pcb. I guess this means the issue is at the interconnect pcb?? Little help here....
#5 14 days ago
Figured it out! Traced the damn thing all the way to the switches for the coin slots. There's a short on the coin door which are part of that particular switch matrix area. I cut the wires on one of the switches and the short disappeared. I was wrong ealier after I tested the connector to the playfield not hooked up and the short remained. Anyway, its fixed. Ha!
#6 14 days ago
Glad we were here to help.
#7 14 days ago
lol...That's what I was thinking.
Sainte Madeleine, QC
Fredonia, NY
Yorktown Parts and Equip
$ 229.00
PinballBulbs
$ 27.99
