I was trying to track down why once in a while the 1000 and 10 score reels only partially reset. I did clean and gap the reset relay switches . Then I noticed a score motor switch in the path and became confused with the labeling.
To the left of the reset relay switch I see IMP (A) and I figure it's the impulse cam bottom switch A. What is the "5" to the left of that? Does it go with the W-G wire, indication that it's the fifth use of that color? Pretty big space between W-G and 5 if so.
