(Topic ID: 195536)
Williams Cyclone U25 Help Needed
By Kickout
6 years ago
  • 22 posts
  • 4 Pinsiders participating
  • Latest reply 6 years ago by Kickout
#1 6 years ago
I posted this earlier, been working on two different pins, a Williams Cyclone and a Gottlieb Extra Ining. So here is a correct plea for help.
Well I just got around to checking out the Williams Cyclone I picked up last week. The prior owner said it lite up put would not play. The first thing i did was remove the old battery hold and replaced it with a new external holder. Checked all the fuses they tested good. Check all connections and looked for any damage on the boards and circuits. Everything looked go so I plugged it in. Turned it on and began the tests procedure. That's where the problem showed. The message read "U25 RAM Failure".
Reading up on this, it appears the U25 RAM is bad. I would like to replace it with a socket ram. Has anyone replaced a U25 with a 6264 NVRAM Module. Read where you won"t need the batteries if you use this. Comments and suggestions need. Should I send it out for repair, or try doing it myself? If I send it out, who does good board repairs.
Kickout
#2 6 years ago
Quoted from Kickout:
Not so fast, check the power supply for 5 volts and 12 volts and see what you are reading.
#3 6 years ago
Will do in the morning.
#4 6 years ago
Checked the power supply at 1J17 on the CPU. Got good readings on the three +5 volts, but got some crazy readings on the + and - 12 vaults on pins 8 and 9. Any ideas where I should start?
#5 6 years ago
What did you get?
#6 6 years ago
Checking voltage on the PSB I get the following.
Coming into PBS at test points , 12, G, 12
At 3J6 Pin 6- 14.02, Pin 7- 5.01, Pin 8- 5.05 and Pin 9- 5.06
On PCU at 1J17 Pin 4- 5.01, Pin 5- 5.05, Pin 6- 5.06, Pin 8- 14.02 and Pin 9- 13.02
On PCU at TPI 5.01
These all appear in order. Any idea what else I should be looking at now.
#7 6 years ago
Bump
#8 6 years ago
How did you connect the remote batteries? Have you tested the blocking diode for battery voltage on both sides?
#9 6 years ago
Attached is a pic of the remote battery attachment. The red wire from the holder is attached to the + and the black is attached to the -.
Took voltage reading from the batteries first battery closest to the red lead 4.67, middle battery 3.33 and battery closest to negative point 1.66 volts. Reading Repairing Williams System 11 Pinball 1986 to 1990, Part Three, says the readings should be just the opposite, 1.66 first 4.67 last. Am I misreading this?
Checked D2 diode getting 3.07 and 3.15 volts.
Checked voltage at U25 pin 24 and got a reading of 4.27 volts
Checked D2 for diode test and got a reading of 1.0 on either end.
Am I correct in thinking that D2 is bad and should be replaced, and not replace U25 as first thought?
#10 6 years ago
This should read the same as the batteries, you got 4.67 volts on the battery.
Quoted from Kickout:Checked voltage at U25 pin 24 and got a reading of 4.27 volts
Was this with the power on or off?
Quoted from Kickout:Checked D2 for diode test and got a reading of 1.0 on either end.
Can you tell us how you tested it?
#11 6 years ago
Tested Following instructions from
by [email protected], 04/21/02.
Checked D2 with DMM set to DC voltage test, game off, black lead to ground strap
Checked U25 pin 24, with DMM set to DC voltage game off, black lead to ground strap
Checked D2 with DMM set to diode test, black lead to ground strap, game off.
Just wanted to say thanks for all replays to date, keep them coming, it's the only way to learn.
#12 6 years ago
looks like you have bigger problems, everything below where battery was has quite a bit of corrosion.
u41 u42 etc
#13 6 years ago
For this test you put each test lead on each of the diodes leads, note reading then reverse test leads and note reading. One reading should be .400-.600 and the other should be OL or infinity.
#14 6 years ago
Well I guess I have to bite the bullet and start looking for a replacement board. Any ideas where and what I should replace it with?
Kickout
#15 6 years ago
I thought you were going to fix this board. Rotten Dog is the only replacement now.
#16 6 years ago
With the battery damage Wdennie pointed out, I'm not sure I have the ability to fix that damage. How hard is it to repair battery damage?
#17 6 years ago
Grumpy
I took the main board out and did a cleaning of the battery acid, cleaned all pins. Put the board back in and to my surprise the game starts goes into attract mode. Put a coin in game starts but only partially plays. Flippers work, ferries wheel works, drop targets and bumpers do not. When into test mode everthing appeared to work. At this time I am leaning more to getting the board repaired. What are your thoughts.
Kickout
#18 6 years ago
I have a thread going on fixing my cyclone. Take a look as it may have some useful info. I ended up going with a new cpu which was about $400. I still had some issues that a pinsider has helped me with. Thunderfoot is my hero! I'm a noob when it comes to board work but I tried to detail what I did. Can't hurt to look.
I had an issue with my A/C Relay. My C side was all working but the A side really didn't work. My relay kept clicking but never worked right. Went through a lot of diagnostics that now helped me to understand things a lot better.
#19 6 years ago
I always lean towards fixing original board when possible, with that said its more time consuming, sometimes not profitable and very frustrating. Since I have been repairing pins for 25 years its a lot easier for me to decide if the problem is worth fixing. For some soldering is difficult enough to begin with and when you add alkaline damage on top it makes it impossible for them. For this board, I have not seen a very good pic of the extent of the damage yet, if the damage has not gone past U-42 there might be hope.
#20 6 years ago
Grumpy,
Here are pics of the front and back of the board. I can start a game but get no scoring. Thinking of replacing U25 and maybe U42. Take a look and see what you think.
#21 6 years ago
It really is a shame as this board has had only a couple of repairs in its life. The damage is very extensive and you may get it to work for a while but it will always be unreliable. If it were me I would cut my losses.
#22 6 years ago
Grumpy,
Thanks for the advise. I will start looking for another board. I'll keep the old board for any good salvageable parts. Anyone got a board they might want to sell?
Kickout
$ 11.95
$ 27.00
$ 69.00
Pinball Pimp
$ 29.99
Daddio's 3D Printed Mods
$ 12.50
RoyGBev Pinball
$ 19.99
3,200 (Firm)
Collegeville, PA
$ 39.99
$ 2.50
$ 44.99
Pinball Shark
$ 170.00
Displays
Digipinball Shop
$ 69.00
Pinball Pimp
3,650
Copley, OH
$ 18.95
$ 36.95
This page was printed from https://pinside.com/pinball/forum/topic/williams-cyclone-u25-help-needed and we tried optimising it for printing. Some page elements may have been deliberately hidden.
