(Topic ID: 336023)
Williams Cyclone ball kicks out into shooter lane when turning the gam
By rdrapeau3171
1 year ago
  • 6 posts
  • 4 Pinsiders participating
  • Latest reply 1 year ago by Zatan
#1 1 year ago
I finished restoring my Cyclone today. As part of this project, I swapped the playfield.
So, when I turn the game on, the game kicks the pinball out into the shooter lane. I then send the ball up the playfield with the plunger, and then it goes into the ball trough and it stays there until I press the start button to activate a game. Everything works fine from that point on.
Any ideas why it would cause the ball to kick out when turning the game on?
Thanks for your help.
#2 1 year ago
If it was okay before the swap. I'd go over your work. Switch wired wrong somewhere ? Switch stuck closed somewhere ? Switch shorting to ground somewhere ?
#3 1 year ago
Quoted from LTG:
Ok, I will check it out and report back tomorrow. Thank you LTG.
#4 1 year ago
So, I checked the switch where the pinball sits in the ball trough and it looked ok, but I adjusted it. It might have been slightly off. That fixed the issue.
Thanks for your help LTG.
4 weeks later
#5 1 year ago
I have a similar issue. I have a Williams F-14 Tomcat and while a ball is in play, one to two balls will get kicked into the shooter lane. Since the plunger is not strong enough to push both pinballs into the playfield, I have to remove the glass. Anyone had something like this happen? I did replace the the display with an LED 11AB. Don't see the connection, but who knows.
3 months later
#6 1 year ago
The switch in the drain seems to be an issue in Cyclone. My switch was slighty bend to one side and was stucked sometimes wich made the hole game go totaly bananas. After a long time of troubleshooting but very easy mechanical adjustment the game went perfect again.
3,300
Lansing, IL
$ 29.99
Daddio's 3D Printed Mods
3,300 (Firm)
Normal, IL
$ 11.95
$ 69.00
Pinball Pimp
$ 19.99
Allentown, PA
$ 39.99
$ 44.99
Pinball Shark
$ 27.00
$ 36.95
$ 95.00
Pinball Mod Co.
$ 69.00
Pinball Pimp
$ 18.95
$ 170.00
Displays
Digipinball Shop
$ 2.50
