Hi all this is my first venture into a solid state machine and it's a whole new world compared to em machines. I bought a Williams contact on the cheap and of course it powered up with no display nor functioning playfield I took the mpu/driver board off and found cold solder everywhere after reflowing everything I put the board back in and realized my solenoid fuse was blown replaced that and turned the machine on that fuse blew instantly but everything else came up I could start a game and it scored moved through the balls and went into game over but no solenoids worked. Now I traced the problem from my power supply to a red wire that goes through a harness then Underneath the playfield to the center pop bumper then jumps off there to every other solenoid on my playfield. I disconnected the red wires from the pop bumper so they were no longer feeding everything else and turned on the machine and the fuse no longer blew. My question is how can I test everything without going broke buying fuses I do have a dmm I know basics with it but I am still really new with solid state machines what would be my next step??
