I'm working on a 1985 Williams Comet.
It needed a flipper power board and a sound and speech board, numerous lights and flashers and had the original rubber on it that has now turned to dust and a clay like substance.
I have everything sorted out and have repaired the cracks and holes in the ramps with Plastix (amazing stuff actually).
All thats left is the backbox lights are not working but after replacing all the flasher bulbs the flashers are working great.
The Playfield GI is perfect and working solidly.
All of the displays are clear and bright.
So Is it a wire off or broken in the backbox? All the fuses are new and perfect, tested many times with a meter.
What would be the first things to check as far as power to the lights in the backbox only?
