(Topic ID: 258119)
Williams BSD sound up not working.. Am I missing something? - FIXED!
By Barakawins1
63 days ago
  • 9 posts
  • 2 Pinsiders participating
  • Latest reply 61 days ago by RussMyers
#1 63 days ago
I'm working on a Williams Dracula. The volume up adjustment switch inside the coin door doesn't work. I changed the adjustment switch and same result.
I swapped the power wire from the down volume switch to make sure the new switch works and it does. I can confirm the new adjustment switch works.
Next, I followed the wiring up to the mpu board (J205), pin 8 (orange/violet) I get continuity from the coin door switch up to J205 pin 8 no problem. So have no wire breaks. Anyone have any other ideas on why this switch may not work?
#2 63 days ago
Quoted from Barakawins1:
Is there any battery damage on the MPU board?
This can affect the game responding to those switches.
RM
#3 62 days ago
No acid damage at all
#4 62 days ago
IIRC, there is a single ground wire that chains from switch to switch - is it definitely attached to all of the switch ground lugs on the coin door?
You have to look closely.
RM
#5 62 days ago
Yes it’s attached.
#6 62 days ago
UGH! The schematics were wrong! Unreal! Compared traces with another board and confirmed schematic drawing was incorrect.
#7 62 days ago
OK, so the underlying problem was what? Bad trace?
RM
#9 61 days ago
Good job.
3,400 (Firm)
Sale Pending!
Albany, NY
$ 999.00
