Greetings Pinsiders! First time poster here, but I got myself a sweet Blue Chip machine about a month ago. It was working for the most part at the time of sale. Fast forward about 100 games - to a game last week I tilted the machine (the normal amount) and the score motor was not successful in completing a reset sequence. I think this issue shouldn't be a bear to track down, but I have started by checking a few things myself and am beginning to become stumped. The schematic on IPDB is also not very good resolution so I sent a couple PM's out to try and obtain one of the crispy looking ones I have seen floating around. Any suggestions are greatly appreciated!
Summery of events since the great tilt incident:
Cleaned all plugs in the machine with scotchbrite and isopropyl alcohol (IPA)
IPA cleaned score motor contacts - not sure I was 100% thorough
Checked 4 fuses at front of machine -sat
Checked 2 fuses on bottom side of playfield -sat
Cleaned/checked contact adj on reset, tilt, 10pt, score reset, bonus reset relay
*Restarted machine*
Only the jet sling/ambient lights are lit.
Added random amounts of score to all reels and hit the start button - score reel switches functioned and return to zero.
Bonus unit did not return to zero.
Bonus unit was in position 1 - I manually moved to pos zero and the score motor completed the startup sequence.
I started a game and I observed that no bonus lights illuminated, but the bonus unit was stepping up normally as i scored a bonus advance.
No target lights 1-8 illuminating but they do initiate chime.
I shook the table and all the lights came on. I drained the ball and the bonus stepped down to zero adding score to the reels appropriately. Launched ball two and the lights flickered out. Upon draining the ball, the bonus unit accumulated points on the score reel infinate loop until i turned the machine off.
I checked bonus unit switches and coils. Both coils read resistance 4-7 ohms. I cleaned EOS and pos switches - seemed to be adjusted correctly from what i read in another thread on pinside. Possibly verified from the instant that the bonus unit worked when the lights flickered on.
*Restart machine again*
Only ambient lights are lit. (no insert lights)
Start game - score reels reset, bonus unit resets, ball outhole functions
I score a few targets and such, no insert lights, but bonus advances.
Drain ball - bonus accumulates properly on score reels.
End of game sequence completes properly and gameover light comes on.
While looking around I find a seemingly unrelated second issue:
10 pt relay - the relay kicks on at the first 10 pt score and never releases. I didn't realize this was not normal gameplay but it makes total sense that we should hear medium chime whenever we hit a bumper. Hopefully someone can explain how EOS works on this coil because its staying off until the first hit of any 10pt action in the game is hit, then on until a tilt or game over. The playfield switches seem to be in proper adjustment. This probably will burn out my score and chime coils if not fixed.
I am suspecting a crumb has fallen to the wrong spot, I have a loose wire somewhere or the tilt has not reset.
Regards,
Jeff
