Hi everybody, I have a Williams Blackout that is very close to being finished and thanks to the wonderful people here on Pinside I have managed to bring it back to life. I thought I would bring the topic out in the open so that maybe more people could see it. When the left flipper is flipped multiple times or just occasionally the soundboard calls out "Mission Completed!" this happens whether you have completed the mission on the playfield or not. It does not add score but it is very annoying because it happens intermittently when the left flipper is flipped. It never happens when the right flipper is activated. The soundboard is brand new from Jeff kohout at Pinball PCB. All the other boards in the backbox are original. Other than this, the soundboard fires exactly when it should with correct sounds and sounds fine. It was brought to my attention that maybe the coil on the left flipper had high resistance and was causing power ripples through some of the boards in the back box and causing the soundboard to fire. I checked both coils and they both measure the same at 1.2. I verified this with coil resistance chart expert John Robertson in Canada. If anyone reading this has any idea what it might be I would really appreciate some pointers...Many Thanks!
