Hi, I just picked up a Williams blackout and the person I bought it from had it plugged in and all the GI lighting was on and a buzz coming from the speaker. I packed it up brought it home and for the last few weeks I've been cleaning and tweaking. I know it doesn't work or start a game, however before I plug this in again I want to see if there's anything I should do beforehand. I noticed the knocker coil was melted and they had clipped and taped the wires. I suspect a bad transistor on the driver board. All other coils look healthy and clean. I removed the MPU and the Driver Board and re-flowed all the pins at the 40 pin connector. All pins and female connectors look clean, no burns or heat stress detected. No acid damage. All boards look remarkable! Does anyone have a chart showing coil/ transistor assignments? i e. Q1, Q7 etc and which transistor fires which coil? I'd like to find the transistor that matches the melted knocker coil.
What should I be looking for at power-up for LEDs on the MPU, or is that even of any value on a system 6? What should it do when power is turned on, dings, sounds, etc? Any other input someone may have would be very appreciated.
Many thanks in advance! Scott
