(Topic ID: 294495)
WIlliams Blackout player lights
By jojo97222
2 years ago
  • 6 posts
  • 3 Pinsiders participating
  • Latest reply 2 years ago by jojo97222
#1 2 years ago
Issue with Williams Blackout. Occasionally the player 1, 2, 3, 4 lights stop working during gameplay. They can start out working thru each player but then stop working. Next ball they may be working again. Game has a new CPU/driver board. We have reseated the IDC wires on the female headers, checked and reseated the wiring quick disconnect to the light board and visually checked all sockets and connections. It feels like a connection issue rather than a board issue but just can't put our finger on it.
What are we missing?
#2 2 years ago
Look carefully at the connectors themselves. The actual terminals in the connectors can fail. I’ve rebuilt connectors and found they can fatigue and loose tension or break off inside the housing after 40 yrs. frequent cause of intermittent connection.
#3 2 years ago
When the score displays go out, is the high voltage still there? There should be a glow in a corner of the displays. No glow equals no high voltage. Knowing that you have high voltage should help troubleshoot the issue.
#4 2 years ago
Will check again at the connectors for fatigue.
Billc479 the issue isn't with the displays, but the player lights above each display.
#5 2 years ago
OK - I misunderstood. You're referring to the controlled lamps.
The only common signal for those lamps is from driver board 2J5, pin 2. Since the board is new, I agree that the issue is not likely on the board. When this happens, tilt the game - the tilt light should come on, and since the light is in the same column, you should see it. If the light does not come on, wiggle the wire at 2J5 pin 2 and see if it comes back. If it does, you should change out the IDC to crimp.
You could also wiggle that wire when the player light goes out to see if the light comes back. If it does, new connector.
7 months later
#6 2 years ago
SOLVED - found the new driver board had a bad solder joint at the transistor. Reflowed it and it is rock solid.
$ 11.00
$ 65.00
2,500
Shepherdsville, KY
$ 42.95
$ 27.95
Berkeley Springs, WV
$ 170.00
Displays
Digipinball Shop
2,200 (Firm)
Chicago, IL
Tools
Pincoder Store
This page was printed from https://pinside.com/pinball/forum/topic/williams-blackout-player-lights and we tried optimising it for printing. Some page elements may have been deliberately hidden.
