(Topic ID: 107034)
Williams Black Knight start up ball locations
By dpkzone
7 years ago
  • 6 posts
  • 4 Pinsiders participating
  • Latest reply 7 years ago by mwsmith
#1 7 years ago
Does anyone know how many (and proper start locations) balls Black Knight needs? Obviously at least 3. I was told proper locations and number of balls is a critical troubleshooting start point before looking deeper.
Thanks!!!
Bill
#2 7 years ago
3. All can be under the apron or 1 to 2 may be in the upper lock with 1 or 2 under the apron. Game should also start if 1 (only 1) is in the shooter lane.
#3 7 years ago
3 balls is correct and they can either be in the trough or you can have one in the trough and two in the upper playfield ball lock.
#4 7 years ago
The game will start with balls in lock trough or outhole, leaf switches on mine seem to react to temp,etc. and even with balls in locations sometimes the game won't start. Switch test is a good check, but make sure to run the test with pinballs and not fingers.
-scott
#5 7 years ago
Thanks all. I'm going to check it all out now. I'll let ya know. Surely I won't be this lucky!
#6 7 years ago
One thing to be aware of is almost all of these leaf switches were assembled wrong at the factory with one blade installed upside down. They can be disassembled and corrected, but the one contact may be damaged from being worn by the backside of the upside down blade. Once the gold plating is worn away, they will be problematic. I've been gradually rebuilding my switches with parts from Pinball Resource.
