I think you're referring to Solenoid 6? If not that one, then it would be Solenoid 1. If you're confident in your soldering ability I would change the two transistors listed, depending on which one is giving you issues. There's no reason to replace coils if they're not burned up, shorted or open. They don't wear out, they're simply just wire of varying thicknesses wrapped around a plastic center piece varying amounts. Like for example, the Ball Thrower coil is wire of 23 gauge thickness, wrapped 750 times. By wiring your coil wrong you sent power where it wasn't supposed to go. Always keep in mind the wire position in relation to the diode band, not the solder lug, when changing coils.
