Got a big guns that is suddenly not firering a flipper, lower right. I rebuilt the lowers a few weeks ago and they worked perfectly after. I finally got around to rebuilding the uppers and replacing the flipper buttons the other day. I made may repairs and buttoned everything up and no lower right flipper. Tested for voltage and nothing. I was getting intermittent firing of the upper right during trying to figure out what went wrong. So I decided to replace the ceramic caps and double leaf switch. I tested the coil and discovered it was bad so I replaced it. Still no love. I checked for continuity from the leaf switch and coil and I have that. Pulled the MPU to reflow J19 but looked fine as pictured but did it anyway. Looking at the schematics I am trying to chase down the path from the mpu but I have no idea where 8j3 or 7p1 are. Also all the fusses I can fined tested as good.
What do I need to look at next?
Don't mind the hot glue. I "potted" a noisy inductor.
IMG_20200727_142257 (resized).jpgIMG_20200727_143921 (resized).jpgIMG_20200727_144107 (resized).jpg
