I am working on a Williams Big Daddy. Everything works except for the ones score reel. It works perfectly in single point scoring. There are a number of rollovers that should score 5 points. They score between 5 and 9 points.
The scoring unit works perfectly if the number reel is removed.
I took several videos of the 1 point relay and slowed them down so that I could see the individual closure of the points and the movement of the armature that holds the points. Everything is correct.
The match unit steps up 1 each time the 1 point relay pulls in. The match unit is stepping correctly.
I took videos of the score assembly with the reel attached. In slow motion, you can see the reel behaving very jerkily. Sometimes it moves correctly, other times it will jump two or three numbers with a single fire of the coil.
I have replaced the coil stop, cleaned the cam shaft that turns the score reel, adjusted the 9 position and 0 position switch riders to cause as much tension as possible with the blades that are on there and adjusted the snowshoe on the under side of the reel. I even replaced the cam shaft. The bottom set of cogs that the coil uses to turn the reel were worn almost smooth.
Nothing makes any difference.
These displays are the ones Clay refers to as rat trap. Gottlieb and Williams used them before Gottlieb went to the Decagon unit and Williams switched to the small plastic reels. I can't find anything that is supposed to act as a brake on the spin of the wheel except the cam followers for the 9 and 0 switches and the catch that prevents the reel turning backward when the coil fires. I replaced that spring too.
Suggestions?
Discussion?
Help?
Thank you
Pinworks
