(Topic ID: 269224)
Williams Argosy won't credit up
By treborlicec
13 days ago
  • 14 posts
  • 4 Pinsiders participating
  • Latest reply 12 days ago by treborlicec
#1 13 days ago
My Argosy won't coin up any longer. It worked for months, but today, it won't coin up. The coin lockout coil is not energized and it normally is. I've verified it doesn't energize even when there are 0 credits on the credit unit. I've checked/cleaned the coin relay and the jones plugs for the coin door. Tried looking for this topic on other Williams EMs but wasn't able to find a solution.
Thanks in advance.
RC
#2 13 days ago
Will the machine add credits (coin up) if you manually close the coin switches? Check the credit unit last position switch with the black/red wire and black wire. When maximum credits are reached on the credit unit, the last position switch on the credit unit will open and it will turn off the coin lock out coils. See if the credit unit last position switch is clean and in the closed position.
#3 13 days ago
There are four switches that must be closed to get the Coin Lockout relay to fire:
Try jumpering around individual switches and combinations of switches to see if you can tease out where the disconnect is.
/Mark
#4 13 days ago
Quoted from MarkG:
/Mark
I'm only seeing 3 that should be closed and 1 open unless I'm not following. I've checked all those switches and they are in the proper position and have good adjustment and are clean. The credit button switch is the start button, correct? And it shouldn't come into play with the lockout coil.
Thanks,
RC
#5 13 days ago
Quoted from treborlicec:
The four switches are reset relay, score motor index A, coin relay and credit unit at maximum. And they should all be closed to complete circuit to coin lockout relay.
#6 13 days ago
Maybe I'm thinking about this incorrectly. I was thinking the coin lockout coil needs to be energized in order to add credits. When I try to manually add credits via the coin switches, nothing happens. Here is the credit unit at 0 credits. Is this last position? The bottom switch is closed.
#7 13 days ago
The coin lockout coil's function is to either direct a coil to fall on the coin switch, or direct a coin to fall into the coin return tray.
You should be able to manually close a coin switch, which will add one or more credits on the credit unit. In order to get power to the credit unit step up solenoid, a 25 cent relay switch needs to close. Do you hear a clicking sound when you manually close one of the coin switches?
The credit unit step up solenoid and the coin lock out coil share the same switch in a shared circuit - the credit unit last position switch (black/red wire and black wire). You can use a jumper wire to bypass this last position switch to see if it will complete the circuit for the the coin switches and energize the coin lock out coil.
#8 13 days ago
Quoted from fredsmythson:
Nothing happens when I manually activate the coin switches on the coin door. In my case, I'm pretty sure that when the coin lockout coil is energized, it allows a coin to go to the switch and when de-energized, it directs it to the coin return, based on how the little blocking bars behave. What exactly should I jumper? I don't want to cause more issues.
Thanks.
#9 13 days ago
fredsmythson and I are thinking along the same lines. Here's the circuit he's referring to.
If neither the Coin Lockout nor the Credit Step Up are working it could be because the common switch in the red box isn't closing. It's hard to tell from your photo which switch it is because of the yellow jumper wires but you're looking for a switch that connects a brown-red wire to a black wire. I think it's the switch at the bottom of the switch stack in your photo under the insulating paper with the black wire. The two switches that are open look like zero position switches.
The brown-red wire should be connected to a solder lug on both the Credit Unit Step Up and Coin Lockout coils in addition to the switch in the red box.
If you jumper from the brown-red wire to the black wire to remove that switch from the circuit, does that change things?
#10 13 days ago
With you guy's help, I may have found the issue. There is a black/red wire that is loose. Couldn't see it in all that mess before. It looks like it should go on one of the lugs of the credit step up coil. There is a yellow wire also on that same lug that does lead back to the last position switch. This sound like the culprit? Don't want to solder it to the wrong lug, but based on what you guys have said and that schematic, I think that is correct.
Thanks.
#11 13 days ago
You're right. The schematic shows black-red (B-R-4) not brown-red.
The short yellow wires are just jumpers to get one wire to multiple places that are close to each other. The jumper wire colors are not shown on the schematic. If the resistance from the loose end of that wire that you found to any of the other end points (Coin Lockout coil lug for example) is about an ohm or less that would tell you that it's the same wire.
#12 13 days ago
Reattaching that wire fixed the coin lockout issue. It now engages when the game is powered on like it used to. I still get nothing when I activate the coin switches. No clicks or motor turns, etc. Dang, thought I found it.
#13 12 days ago
There's a fair bit of complexity to the coin circuitry to enable variable pricing but the one thing that could disable all the coin switches is the Anti Cheat switch.
#14 12 days ago
Quoted from MarkG:
That was it. Thanks so much. It was spread apart like alot of slam tilt switches are on old games, but this one needs to be normally closed, not open. Weirdly, it coined up previously, so not sure what caused it to be part of the issue months later.
Great American Pinball
$ 12.00
$ 48.00
$ 7,599.00
Operation Pinball
$ 29.99
$ 71.99
Lee's Parts
$ 154.00
Id Rather Play Pinball
$ 29.95
Apparel - Unisex
The GameRoom Store
£ 20.00
$ 99.99
$ 37.00
The MOD Couple
Pinball Z
$ 79.95
pinballmod
$ 49.95
pinballmod
$ 132.00
