Hi game is stuck on ball 1 does not advance to ball 2.
Raff
Quoted from Studentprince:Does the ball index relay pull in when you score 100 points?
I will have a look at it.
Raff
@Raff--Check the trough switch and make sure it is closing when the outhole kicks the ball across to the shooter. Also, on older games that have sat for awhile, the player unit will get gummed up and not advance either to the next player or the next ball. AZKenny
Quoted from AZKenny:@Raff--Check the trough switch and make sure it is closing when the outhole kicks the ball across to the shooter. Also, on older games that have sat for awhile, the player unit will get gummed up and not advance either to the next player or the next ball. AZKenny
Trough switch,is good.
Manual activate the ball count unit not a problem .
Raff
Raff -- One minor note that could help you. Your game has what is known as a closed in play field. In other words, the ball must pass over one of two rollovers before getting to the main play field. Rolling over one of those rollovers might be what must happen first to engage the ball Index relay. AZKenny
Quoted from Raff:Hi game is stuck on ball 1 does not advance to ball 2
If the Ball Count stepup solenoid doesn't activate when the Outhole relay does,
Inspect and diagnose this circuit with Alligator clip jumper wires
https://pinside.com/pinball/forum/topic/gottlieb-big-shot-repair#post-6305153
http://www.planetimming.com/Pinball/troubleshooting/EM%20Troubleshooting.pdf
http://www.pinrepair.com/em/index3.htm#features
Example of a pinsider actually doing this https://pinside.com/pinball/forum/topic/red-baron-tech-question#post-5858156
Problem fixed
Not really sure what the problem was just manual moved the match unit and the ball count started working.Thanks to all for helping
It was pulling in .
Raff
This page was printed from https://pinside.com/pinball/forum/topic/williams-aces-and-kings and we tried optimising it for printing. Some page elements may have been deliberately hidden.
