Hi Mark
DANGER --- Your pin is an rather old one and has a lot of stuff operated by 110VAC. You do not want to get killed --- so ALWAYS unplug the 110VAC main power cord: When "working in the pin" --- when "just looking". ONLY plug-in when You NEED current for a test.
See JPG-1 (an old one - I happened to use "chasing fuse blowing") - only look at "RED" wiring: ALL RED WIRING is permanently connected to 110VAC-POWER when You do have the cord plugged-in --- DANGER.
Troubleshooting in Your pin: See the top of second JPG - the Game-Over-Relay (the drawing is actually "Bally-Game-Over-Relay") --- UNPLUG the main power cord and look at Your Game-Over-Relay --- it MUST be tripped - You may have to trip it manually. Then plug-in and try the Left Flipper-Button.
No Luck means The Lock-Relay does not pull-in ? --- The "green stuff" shoes the "Kickoff-Switch" - maybe faulty. UNPLUG the main power cord and establish a permanent Jumper "my yellow stuff" - see the yellow dot on the transformer - having soldered-on two wires "yellow". Then plug-in and try.
Still no luck --- UNPLUG the main power cord and establish one more jumpering - my "RED" --- PLEASE DO USE "side on 15 Amp Fuse where wire-BLACK is soldered-on" --- as we want the fuse in our wiring. So by now You have a permanent jumper "yellow" and You have a permanent jumper "RED". Then plug-in and try.
- No reaction at all means Coil on Kock-Relay is dead.
- Fuse blows means the coil is shot making a short.
- Lock-Relay pulls-in and stays pulling means we must look at wiring and switch on Game-Over-Relay.
- Other reaction (?), hmm
Greetings Rolf
P.S.: See in the first JPG - "encircled orange": As long as You press the left flipper-button: As long YOU feed 110VAC to transformer.
