(Topic ID: 221670)
William’s ‘68 Pitstop (need some basic maintenance advice/tips)
By Mandos
5 years ago
  • 12 posts
  • 4 Pinsiders participating
  • Latest reply 5 years ago by Mandos
#1 5 years ago
Hi guys, new guy here(sure you hear that a lot), and I’m in the middle of doing basic maintenance on his ‘68 William’s Pit Stop. He’s had it since at least ‘72 when he pulled it out of a bowling alley he owned, and it’s been in his house and office since then and my dad grew up playing it. So the good news is it had only a few years of commercial use at most, and it’s been fired up at least once a year since then so it’s completely working mechanically. Downside is it’s had almost no maintenance done over the years. So I have some before pics, then pictures of what I’ve done already. The rubber was completely worn out so I got a replacement kit, and I’ve already swapped it all out except the plunger tip(which I also have replacement spring for, although it’s still in decent shape).
So reason I’ve made this post, is I want to do further maintenance but need some tips and advice. The play area has a thick layer of dirt, so I was wondering what the recommended cleaner/wax was since I obviously don’t want to damage the paint. The other priority thing is cleaning the glass, but I was just planning to set it a good distance away and just use some standard window cleaner and let it dry while I wax the play area(the play area glass I mean)
I would like to do some additional repairs and clean up work, the outside of the cab is pretty battered, and the inside could use a cleaning too, along with the scoring glass needing some form of resealing. On the upside I do have all the original documents too which is nice. But the biggest thing is the wax recommendation because my dad would love to have the critical stuff done this week so he can fire it up and play some rounds
The pics are kinda in random order, but I’m sure you guys can tell which is with the new rubber. Also took a pic of all the old rubber I pulled out(the bottom bumpers only gave out a year or so ago, the rubber I mean). I’m also fixing this guy up so I can use it and actually get some pinball skills down.
207AEBD5-2491-4DE4-BDAC-EE46C5E89E10 (resized).jpeg207AEBD5-2491-4DE4-BDAC-EE46C5E89E10 (resized).jpeg263D4A2F-619A-488D-95F8-D554EEA22173 (resized).jpeg263D4A2F-619A-488D-95F8-D554EEA22173 (resized).jpeg28654B88-3FA1-4493-83B4-E453EA8141E0 (resized).jpeg28654B88-3FA1-4493-83B4-E453EA8141E0 (resized).jpeg2D7A8A7F-582C-4313-BA85-4011FEE45379 (resized).jpeg2D7A8A7F-582C-4313-BA85-4011FEE45379 (resized).jpeg3762EE26-23E8-4C9B-B58A-80ECC2D09A11 (resized).jpeg3762EE26-23E8-4C9B-B58A-80ECC2D09A11 (resized).jpeg534A53AD-A1E6-471D-BFB5-2FA22FF00084 (resized).jpeg534A53AD-A1E6-471D-BFB5-2FA22FF00084 (resized).jpeg6A72DF85-6C88-4CD8-8929-E89FEE44CD2D (resized).jpeg6A72DF85-6C88-4CD8-8929-E89FEE44CD2D (resized).jpeg7058CD2E-926B-40E1-8C59-EF4BAE4B1CC3 (resized).jpeg7058CD2E-926B-40E1-8C59-EF4BAE4B1CC3 (resized).jpeg835A0BAA-AB90-4CF4-BDBB-656877CC0A07 (resized).jpeg835A0BAA-AB90-4CF4-BDBB-656877CC0A07 (resized).jpeg98EB02AC-1E33-473E-B72C-8235657DB81C (resized).jpeg98EB02AC-1E33-473E-B72C-8235657DB81C (resized).jpeg9C12DEAD-B14F-4AB8-B162-C303C961F71D (resized).jpeg9C12DEAD-B14F-4AB8-B162-C303C961F71D (resized).jpeg9DFAE7BC-0040-48D2-AD1E-10FACC080ACB (resized).jpeg9DFAE7BC-0040-48D2-AD1E-10FACC080ACB (resized).jpegAF3978C6-65F7-470A-8B95-209BFB372D5D (resized).jpegAF3978C6-65F7-470A-8B95-209BFB372D5D (resized).jpegBD78F45F-D108-4864-80D0-7BCE69BCF9EB (resized).jpegBD78F45F-D108-4864-80D0-7BCE69BCF9EB (resized).jpegC41346D6-0682-4979-BEEF-082DB050808B (resized).jpegC41346D6-0682-4979-BEEF-082DB050808B (resized).jpegE533E810-1E48-4D24-8EF4-616BD27CBC9F (resized).jpegE533E810-1E48-4D24-8EF4-616BD27CBC9F (resized).jpeg
#2 5 years ago
This might be helpful to you:
http://www.pinrepair.com/em/index3.htm#mid
Read right through the entire section for EM stuff and it'll help you with most general maintenance and repair work you'll come across with your machine.
#3 5 years ago
You can tell this Pit Stop hasn't had much play, because the advance bumper cap doesn't have a big burn spot on it...
If you search Pinside, you'll see there are thousands of opinions on how the clean a pinball playfield... My technique to clean this playfield would be to remove the top arch plates, the apron and all the playfield plastics and posts. Start by wiping down the playfield using light pressure with rubbing alcohol to remove any surface dirt. Then use Novus 2 to clean and polish the playfield. And, finally, use two coats of carnauba wax on the playfield. Clean all of the playfield plastics and posts with Novus 2. You can clean the apron and arch plates with a non-toxic cleaner like Simple Green, Purple Power, Mean Green, etc. Reassemble the playfield and you're ready to play...
Make sure the game ball is in good condition with no pitting. If there are tiny black marks on the ball, just get a new ball...
For cleaning the playfield glass, remove the glass from the cabinet and clean both sides of the glass with any type of glass cleaner. Make sure the glass is completely dry and then reinstall it in the machine...
Exterior cabinet cleaning - you can use a non-toxic cleaner again, a Simple Green type cleaner, and use a fine Scotch Brite pad to clean the dirt from the surface of the cabinet...
The interior of the cabinet can be vacuumed and wiped with a cleaning cloth. The main board at the bottom of the cabinet can be unbolted and removed for better cleaning access. For extreme cleaning, which is rarely done on the inside of the cabinet, you can get a small steam cleaner with a hose that will easily clean between all the relays...
#4 5 years ago
Welcome to the Pit Stop Club! You are in rare air here for sure. Odin is our Honorary President.
Here is a good reference from Vid for cleaning your playfield - https://pinside.com/pinball/forum/topic/cleaning-and-waxing-pinball-machines-vids-guide
Short answer is clean it Naptha then wax it with carnuba. You'll want to take everything off the playfield again so you can get to every nook and cranny.
Do not use Novus 2 on the playfield. I can tell you from experience the paint is too delicate to withstand it.
#5 5 years ago
Thanks you guys, I needed a bit of advice after reading the original manual it saying to use nothing but wax on the play area, I’ll look through some of these. I don’t think I’ll do a full tear down and clean at those point, most of the dirt is in the actual play area, plus I’m not up to putting it all back together at this point in time. Also I had Novus 1 reccomended before, but I was unsure due to the age of the table. Also I already got a replacement ball in the repair kit I got.
#6 5 years ago
To defend Novus 2, I've been using it on "EM" playfields for over 30 years with no adverse effects. If you look at the ingredients of Novus 2, it's one of the safest cleaners/polish to use on a playfield... Unfortunately, using just wax will not clean the playfield and it will create a wax/dirt combination that will greatly increase wear on the playfield... Three, Two, One... Let the playfield cleaning debate begin...
#7 5 years ago
Well perhaps I should point out, I’m mainly cleaning dirt off the play field, it’s entirely possible the table hasn’t been waxed since it left the factory(or at least the early 70’s)
#8 5 years ago
Quoted from fredsmythson:
Ok. I tested Novus 2 on my pit stop. It took off paint.
I wouldn’t recommend it for a new em owner who is inexperienced at cleaning playfields.
For some reason all the pit stop playfields I have seen have been more fragile than other pfs of the same era.
Use naptha and go slow.
I use N2 on a lot of stuff, but wouldn’t on this one.
#9 5 years ago
I've been using Novus 2 on my Pit Stop for 20 years and I've never had a problem. If the playfield paint is extremely dry and the paint is peeling, then any cleaner/polish will remove the playfield paint. The playfield that Mandos is working on just looks dirty...
#10 5 years ago
I think I’m going with the Naptha, better safe than sorry. Plus it is dirt, and not too thick either, although with the heat this we’ll see if I get over there to work on it in the first place
#11 5 years ago
Ok, Naptha and p21s ordered, should be in next week just need to pick up some rags. Also, I don’t plan to do a full field breakdown, I don’t have the time, or want to risk messing it up, first time out I’m only doing a practical clean for play areas. Plus my dad really wants to fire it up again and I’ve kept him waiting long enough
#12 5 years ago
Ok, got both of them in, just need to grab some shop rags(those would be fine right? As in new ones) then I’m in business to clean everything up tomorrow, um, just carefully clean the play area with the Naptha, make sure it’s all dry then do the wax right? Anything else I should know?
$ 12.00
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/williams-68-pitstop-need-some-basic-maintenance-advice-tips and we tried optimising it for printing. Some page elements may have been deliberately hidden.
