I built a Williams System 3-7 solenoid driver tester today I felt like showing off. This makes testing every solenoid circuit safer and easier.
The design is very straightforward. One LED for each solenoid. Positive side of every LED is in common and gets a wire with an alligator clip on the end (to attach to +5 VDC). Negative lead of every LED goes through a resistor (i used 270 ohm because i had a ton of them) than out to a connector wired just like a normal game would be.
