Quick question. Got a firepower in which all displays are missing segment d, the bottom segment. It's an IC version, not discrete. I'm thinking it must be the BCD decoder, because if it were anything else, it would be only some displays missing the segment. So I guess question one is: Is there any way that IC4 could be involved, or is just likely to be one of the BCD decoders? And question two is: How to you tell which decoder it is? Are the ABCDs that come in on 4j6 just the names of what re more or less data lines? Why use the same four letters with two sub numbers?
