(Topic ID: 292334)
Williams 21 Pinball Repair
By fmspin
2 years ago
  • 7 posts
  • 5 Pinsiders participating
  • Latest reply 2 years ago by fmspin
  • 21 Williams, 1960
Williams Rocket.pdf (PDF preview)
#1 2 years ago
I recently picked up a Williams 21 which is in really bad shape. I got it to turn on and a handful of lights on the back glass and on the play field light up. The machine is missing its coin door, however I think I found the correct wires to trigger the start of a game.
Whenever I do trigger the start of a game, the ball release coil energizes and releases the balls, and the back most relay which I believe is the game over relay stays on and buzzes. The only issue is none of the flippers work. Plus the score reels never reset either.
I think the machine is stuck in a state where it can’t finish the initial startup sequence due to something being in the wrong position. However, I can’t seem to find schematics anywhere for this machine to determine which items need to be reset to trigger the game to start.
Any help would be greatly appreciated!!
#2 2 years ago
Do a search for ‘Williams startup sequence’ to get a chronological description of the things that need to happen. It sounds like the score motor isn’t running, which would precede the score reels, so you should have relatively few things to check.
#3 2 years ago
Quoted from fmspin:
This snippet is from a '59 Rocket, but hopefully is somewhat similar. Have you checked all of the switches on the ball trough? Also give the Lock relay a good lookover.
#4 2 years ago
You may have a two-coil Start Relay as (partly) shown in the snippet from currieddog or you may have a Coin Relay. Either way, they typically (in that era) would turn on a Reset Relay to do all the heavy reset work. Since this game has both score reels (for card points) and stepper units (for thousands and millions), there is a lot to do.
You'll probably need to get comfortable with actuating relays and steppers by hand, first with the power off, then with the power on. The diagnostic technique I have in mind is that while it's trying to reset, you manually help the steppers get to their reset positions. If the Reset Relay drops off when everything is properly reset, then you start isolating the various things that had to reset. You can also look at the Reset Relay and see if there are switches that are stuck closed or open.
Pinball Resource might have the schematic.
Also, it helps to put your city/town in your profile. You might be near a helpful Pinsider.
.................David Marston
#5 2 years ago
Quoted from dmarston:
Haha, so used to posting snippets ... here is the whole thing.
Williams Rocket.pdfWilliams Rocket.pdf
#6 2 years ago
Pinball Resource should have the schematic.
http://www.pbresource.com/mansch.html
#7 2 years ago
Thanks everyone for the information! I'm going to start looking at manually resetting some of the reels and relays outline by the startup sequence this weekend. And thanks for the schematic! It at least gives me a rough idea of some of the basics for my era of machine!
This page was printed from https://pinside.com/pinball/forum/topic/williams-21-pinball-repair and we tried optimising it for printing. Some page elements may have been deliberately hidden.
