Among the last problems I am having with my EM, the bank reset is not resetting and I am not getting the Suit (Hearts, Diamonds, etc..) lights at startup. It works about 5% of the time. It looks like this coil (D-24-1400) is fired by either the Coin or Hole contacts making the series connection to 110V, but I see one set of contacts just to the right of these labeled "C and C-4" just under the toggle switch? Anyone know what this is?
In theory, if I just move the Coin or Hole contacts together, should this bank reset coil at least try to move? I found the fuse to it intact, but it is not a 1.6 Amp fuse, but a 1 Amp, Slow Blow.
I will add that I sprayed some professional grade contact cleaner (DeoxiT) into the Coin and Hole area contacts and it seems to be doing a little better after about 10 plays. I also removed all of the Jones Plugs from the head and base and cleaned these as best I could.
Sorry I cannot add a picture from this computer.
