Hi Barry
from post-1 I take a "ONE-player-game" works fine - the problem shows up when playing a 2,3,4-player-game when the first player looses ball-2. This is strange - by now I do not have an explanation so I ask questions to help me getting to the place for to investigate.
I refer to http://www.ipdb.org/showpic.pl?id=1072&picno=35542 - in the picture (on the bottom) the left arrow is lit - when the player looses the ball: He gets 5000 bonus points due to "lightet LEFT Bonus-Ladder". Please play a ONE-Player-Game - well, have the playfield up and manipulate on the playfield - I ask You to always have / make some bonus on the left and have / make some bonus on the right (NOT the same amount, good example: 2 on the left, 4 on the right).
Then with playfield UP: Loose the ball means use Your finger so the Switch below the Outhole is closed - "lit Bonus-Ladder" will be counted down, then "unlit Bonus-Ladder" will be set to Zero, then the pin beats Your finger - he / it wants to kick the ball over to the Shooter-Alley - so take Your finger away.
(In the ONE-Player-Game) sometimes "loose" a ball when "left arrow" is lit - sometimes "loose" a ball when "right arrow" is lit --- question: BOTH ways work fine ?
My description is for "left arrow" - look in the pin - do You see these things happen ? With a finger You manipulate "looses ball" - Outhole-Switch is closed - "LEFT Bonus-Relay" pulls-in and stays pulling" - Score-Motor runs and the left Bonus-Ladder is counted down - when reaching Zero-Position: "left Bonus-Relay" lets go - OUTHOLE-Relay pulls-in --- then more stuff is done.
NOW start a 2-Player-Game, play Player-1-Ball-1, play Player-2-Ball-1, on Player-1-Ball-2 make some points, make "2 bonus on the left, 4 bonus on the right - means different settings" - have the "LEFT arrow" lit - manipulate with a finger "ball is lost" AND WATCH --- question: DOES the pin do the SAME as it did in a one-player-game ? "LEFT Bonus-Relay" pulls-in ... lets go - OUTHOLE-Relay pulls-in ?
You do have a running pin "ONE-Player-Game" - You can watch the "left-Bonus-Relay" and "Outhole-Relay" stuff - I want to learn "First difference" in behaviour doing the "sequence / succession" ONE-Player-Game versus TWO-Player-Game, end of Player-1-Ball-2.
Again: By now I do not have an explanation - by now I want to learn about "Left Bonus-Relay" and "Outhole-Relay" - and: Does a ONE-Player-Game FULLY works ? - loosing a ball "LEFT red arrow lit" versus "RIGHT red arrow lit" ?, greetings Rolf
