I have a 1966 williams pitch and bat and the grand slam target does not work. If you trip the target or the coil nothing happens. Any Ideas on how to fix / trouble shoot? Every thing else works great.
The best way is to ask yourself what happens when a target is hit?
check the target in question first - look at its contacts clean & readjust if needed.
then go to the backbox and check the relay coil with the same value - 1pt, 10pt etc.
if you cant find the coil hit another target (same point value) and see which relay operates .
On some games low points are tied into a change relay or stepper unit,
thats how you get '1 point or 10 points when lit' along with lamps turning on/off.
however this is what I come across in a pinball machine I never worked on a pitch/bat
-good luck
I have that same game! you must have baserunners in order for it to work. Email me. It would be col to have another source to help bounce troubleshooting of of. My email is [email protected] I enclosed a pic of mine. I am also reproducing the backglass (95% done) I also have made repro targets and coin door stickers
This page was printed from https://pinside.com/pinball/forum/topic/williams-1966-pitch-bat-issue-with-grand-slam and we tried optimising it for printing. Some page elements may have been deliberately hidden.
