(Topic ID: 191565)
Williams 11b coil locking on
By the96stang
2 years ago
  • 3 posts
  • 3 Pinsiders participating
  • Latest reply 2 years ago by GRUMPY
#1 2 years ago
I have a whirlwind thats locking on the upper left jetbumper. It is a board issue and not a playfield issue because it does not happen with another board in it. I pulled the board and tested the transistor. Transistor tests fine.
What else would cause a coil to lock on (and blow the fuse)?
#2 2 years ago
Hi,
A short on the board. Have you checked Q75 AND the 2N4401 Q74 ? Although I do not see the fuse blow if the coil is good and is not short.
#3 2 years ago
With 1J19 disconnected you can power on the game with out worry of melting the coil and then start troubleshooting. In attract mode check U-45 pins 11 and 12 for DC voltage (should be more than 2.5 volts). If this is good the check the base leg of Q-74 for voltage (should be less than 0.8 volts). Lastly check both legs of R-96 and it should read zero volts. Let us know what you find.
$ 839.00
$ 50.00
$ 259.95
Pin Stadium Pinball LEDs
$ 279.95
PinWoofer
$ 40.00
4,895
West Chicago, IL
