Hello pinside from minnesota!
My father has recently bought a non functioning William's united Seville shuffle alley. I have checked Clay's guide for EM William's startup sequence but my machine is missing a lot of the relays that pinballs use to start up. Sometimes when you put a quarter in the front it will immediately reset, now all it does is add players, its also what the start button does. I'm not sure if I just have switches or relays mis-aligned or if the machine is just losing power somewhere? The transformer seems to be making the right amount of AC voltage, shes not popping any fuses at startup. This is my first EM machine and I just dont know where to look from here, any help is appreciated a lot, I also have a DMM
I've tried just manually engaging the start relay but nothing happens, it's like it gets no voltage like its dead but it could be that it depends on other relays engaging first before the machine gives it any power
