I've run into the next roadblock in my attempt to revive my strato flite.
In single player games, the game starts, plays correctly, scores correctly, and the end of ball sequence works with bonus countdown and ball eject.
However, it does not advance to ball two.
In multiplayer games, it's the same as above but does not advance to the next player.
I've checked the stepper units for ball advance and player advance. They both move freely and I can advance both manually with success and play the ball with correct scoring. Same issue though, player 2 doesnt advance to player 3. 3 to 4, etc. I can play complete games by manually advancing the ball and player steppers.
Ive followed a few other posts which led me to the ball and player advance switches on cams 2 and 3 of the score motor. Ive cleaned these switches and they appear to be opening/closing correctly. All the soldered connections look good
Ball index relay closes when a score registers and holds.
My next step was going to be tracing the wires from the switches on the score motor to the stepper units. This is where I'm running into trouble. I assumed, probably incorrectly, that it would be a straight wire run from the score motor switches to the stepper unit coils. However, the wire colors do not match up, so there must be something in between that I'm not seeing.
I also have what I thought was a separate problem. Occasionally I'm unable to start a new game even with 20+ credits available. If I manually add one credit from the coin door I can then start a game with any number of players.
Reviewing the schematics I see some relationship between the player unit and coin unit so now i wonder if there is something here to investigate.
Any thoughts on my next best move to narrow this down?
