(Topic ID: 125805)
William master display segment ghosting help identify
By ripple
8 years ago
  • 2 posts
  • 2 Pinsiders participating
  • Latest reply 8 years ago by barakandl
    #1 8 years ago
    I have a William 3-6 master display that has ghosting (partial lighting) on the top segment. Also player 1 and 2 show the same ghosting. It must be one if the IC chips because I have other master displays that are not showing this problem. Any one have an educated guess of which chip is the problem? Thanks.
    #2 8 years ago
    IC5, 4543, is the decoder IC.
    IC9, 7180, converts the logic level to -100v
    R1 is a 10k resistor in series between the 7180 and display glass for segment "a" the top one.
    Make sure R1 isnt fried before fussing with IC chips, specially the obsolete one, the 7180.
    If you know how to use a logic probe. Compare the "a" segment output from the decoder to all the other segments. Find out if there is a logic level issue before it ramps down to a -100v signal.
    This page was printed from https://pinside.com/pinball/forum/topic/william-master-display-segment-ghosting-help-identify and we tried optimising it for printing. Some page elements may have been deliberately hidden.
