I've almost got my aztec running. It's been stored in my decently dry basement for 20 years. I've messed with it off and on, never completely running well.
I recently cleaned all contacts and closed every relay by hand to see that the switches are at least close to making and breaking correctly. I cleaned the stepper units. But didn't tear them down because thy seem to function correctly and I'm scared to tear them down.
Now when I start the game, the coil relay pulses quickly, but does not stay in long enough to turn the score motor even one turn. It also latches the game over and pulses the reset relay. If I hold the coin relay in, the machine resets and usually starts a game. I see arcing in the switch that runs the score motor when I hold the coin rely in. I adjusted and cleaned the switch in case it was not making goo contact, but it stil arcs. Ii seems like my problem is the coin relay not staying in. I looked through the start up sequence and schematic, I just can't figure out what to go after.
Any suggestions?
Thanks,
Bob
