nothing related to mmr, but i'm confused with this coin mech / comparator - as there are no switches, etc.
Will this work for WPC games?
thanks,
rick
thanks,
rick
Many will work in a WPC game. Problem will be the manufacturer - is anything available to hook it to and program it to American ( or what ever country ) coins.
LTG : )™
http://na.suzohapp.com/wp/search.p?SECTION=ALL&SEARCH_TXT=35-0003-00&Search=GO
Duh lol ... here is the link ...
rick
That looks like a mechanical coin mech - not really what I consider a comparator. Maybe I have my terminology wrong, but I always thought a comparator was the electronic device that 'looked' at a coin, and decided what the value of the coin was, or rejected it if it were not a known value / counterfeit.
If it's the 100 series from Coin Mechanisms Inc, which it appears to be, it's probably this mech:
http://www.coinmech.com/product_profile.cfm?id=524
You might want to contact Coin Mech Inc and see if PPS or BAA could become a distributor.
If you're looking for mechs, though, there are better buys for your dollar. Terry has all metal ones for $10. The Happ Ultimech is nicer plastic mech that costs less than the one you linked. Imonex makes a nice mech at around the same price that will even take bent quarters.
Not knowing your motivation, I can't speculate too much, but there are options out there that perform better or cost less, depending on what you are looking for.
That is, in fact, the stock mech supplied for any Coin Controls coin door supplied on a US game, before WMS switched to the Entropy doors.
The only catch is, it might ship with only the left-side studs installed; coin controls doors don't use right-side studs.
(come to think of it, I don't think entropy ones do, either)
Yup, That's a regular run of the mill 25 cent coin mech. The "comparator" part is simply the small odd shaped wheel on a "pin" (i don't know the real part name) which tilts that is machined down to the micron in size to allow only a US quarter to pass through. If you use tokens, you can get the same looking acceptor (coin mech) that takes whatever size tokens you use.
You should also be able to purchase a bag of spare studs. Your coin mechs will have pre-drilled holes on both sides.
Quoted from videorob:Your coin mechs will have pre-drilled holes on both sides.
As long as they aren't the plastic molded on ones.
And depending on manufacturer the threaded holes can be different sizes and metric or American.
LTG : )™
Quoted from LTG:As long as they aren't the plastic molded on ones.
LTG : )™
Good point. I was assuming metal as the plastic ones.....well you get what you pay for.
I did not know about the size variance and Metric vs Standard. Never came across that yet. Learn something new every time I come here.
EDIT: on Metric vs Standard. I either never came across that or I cross threaded a butt load of coin mechs!!!! Probably the latter.
I know a ton of game ops that swore by the plastic acceptors ... with no moving parts they loved 'em; was impossible to gum them up with beer, etc.
They DO wear out over time though ... metal coins sliding through plastic = wear, and once wallowed out the slide passages stop working correctly.
Plastic stubs can be cut off, and if needed again, you just drill a hole and screw a metal one in its place.
A good operator never lets something as simple as that get between him and quarters in the bin!
(wink, wink)
This page was printed from https://pinside.com/pinball/forum/topic/will-this-coin-mech-work-on-wpc-games and we tried optimising it for printing. Some page elements may have been deliberately hidden.
