Hi Everyone,
I am in the process of restoring a 1969 Gottlieb "Wild Wild West" pinball machine and was wondering if I could get your help.
The machine's left vari-target assembly has significant friction, and does not return to its neutral position when the solenoid holding the return spring is triggered. The friction seems to be in the vari-target assembly's shaft, which is pressed together, so I am not sure that it is repairable given my tools. As such, the easiest way for me to fix the problem would probably be to buy a new vari-target assembly.
Unfortunately, I do not have a manual for this machine. Could anyone provide a part number for which vari-target assembly this machine uses? I found 3 different vari-target assemblies on Marco Specialties, but none of them are listed to be compatible with this machine on their website, so I am not sure which one to buy.
Alternatively, does anyone know if a PDF of a manual for this machine is available somewhere online? I have not been able to find anything through Google...
Thank you for your help!
