(Topic ID: 245909)
Wild Schütz - conversion of a Strikes and Spares documented
By WeirPinball
1 year ago
  • 31 posts
  • 6 Pinsiders participating
  • Latest reply 10 months ago by WeirPinball
  • Topic is favorited by 17 Pinsiders
There have been 65 images uploaded to this topic. (View topic image gallery).
#1 1 year ago
Decided to try a documentation of this conversion since I don't think there are many Wild Schütz games out there. Customer has brought in a Strikes and Spares donor game and a conversion kit including new cab art (metal overlays), plastics, backglass and a playfield. I will do my best to document the progress - which will be quite a journey.
Scott
#2 1 year ago
First step was to strip the cabinet and mock up the replacement artwork to determine what areas need to be painted.
#3 1 year ago
Mock-up of artwork installation, note where the new artwork doesn't cover the wood - this will be prepped for paint. Bottom of cab has been repaired poorly, so that will be removed and replaced.
IMG_1092 (resized).JPGIMG_1093 (resized).JPGIMG_1094 (resized).JPGIMG_1095 (resized).JPGIMG_1096 (resized).JPGIMG_1097 (resized).JPGIMG_1098 (resized).JPGIMG_1099 (resized).JPGIMG_1100 (resized).JPGIMG_1101 (resized).JPGIMG_1102 (resized).JPGIMG_1104 (resized).JPGIMG_1105 (resized).JPGIMG_1106 (resized).JPG
#4 1 year ago
Cabinet will now be prepped for paint. Artwork is sanded off first. I use a festool sander with dust collection - 60 and 120 grit.
#5 1 year ago
Cabinet back was loose, so it is glued and re-fastened.
#6 1 year ago
Major filling is done with epoxy wood filler.
#7 1 year ago
After the epoxy cures it is rough sanded, then a skim coat of wood filler is appied to the entire surface.
#8 1 year ago
Ive done a few Geiger conversions, they are fun builds
#9 1 year ago
After the skim coat is dry (at least overnight) I block sand with 220 to get a general flat surface.
#10 1 year ago
After the initial block sanding - there will be low areas that need to be refilled - this will be repeated until it is as flat as I can get it.
IMG_1145 (resized).JPGIMG_1146 (resized).JPGIMG_1147 (resized).JPGIMG_1148 (resized).JPGIMG_1149 (resized).JPG
#11 1 year ago
Meanwhile - I stripped the insert panel down to spray paint with Krylon painter's touch 2x white primer.
#12 1 year ago
Man... now you got me thinking of fixing my strike and spares cabinet. Going to be following. Thanks for sharing.
#13 1 year ago
Another coat of filler applied to low spots for leveling.
#14 1 year ago
Bottom will need a piece of plywood
#15 1 year ago
Vent holes need the excess filler removed - I'm using an small knife to clean them out.
#16 1 year ago
First light coat of primer applied - painter's touch 2x primer after tack clothing the wood to remove any dust.
#17 1 year ago
The primer helps show areas that need more fill and sanding.
#18 1 year ago
Very thin layer of wood filler applied to areas - note, one area of lamination started to lift, so I will have to fill this with the epoxy to repair - always better to remove it and fill unless it can be glued down.
#19 1 year ago
Sanded and primed again
#20 1 year ago
Prepping plywood panel to fix bottom board.
#21 12 months ago
Bottom board repaired with plywood glued and stapled. Coin door is getting re-skinned and cleaned.
#22 12 months ago
Insert painted and fixed a burnt connector that was hacked.
3 weeks later
#23 11 months ago
Cabinet back from paint - paint color is "arcade white". Apron and shooter gauge will be customized so they were painted the same color. Cabinet will start to be assembled next.
#24 11 months ago
Head artwork loosely installed - still has protective plastic on it.
#25 11 months ago
Are the metal overlays held on with screws?
What an odd way to change the art.
Looks good so far.
#26 11 months ago
Quoted from RCA1:
Looks good so far.
I'm using twist nails - same way siderails are attached on this era game.
#27 11 months ago
Main cabinet artwork being laid out for installation.
#28 11 months ago
Can you give a bit of backgroud- what is this conversion kit all about? Theme? Old? New?
I dont even know what the title refers too... but I never was a cool kid so maybe its just me.
#29 11 months ago
Quoted from rufessor:
https://www.ipdb.org/machine.cgi?id=4017
#30 10 months ago
Cabinet set up and going back together.
#31 10 months ago
Donor playfield stripped and mechs out for rebuild.
$ 22.50
€ 3.95
Multigame
Displays
PinballSolutions.eu
Third Coast Pinball
