Great idea and thread - ordering some now to try
Quoted from Spyderturbo007:This guy makes decent mounts. They aren't as nice as the $180 one I have upstairs, but they also aren't $180.
https://www.makesbymike.com/
Thank you! I just ordered that!
Quoted from Bos98:I use Gosund plugs from Amazon. 4 for $25 on sale fairly regularly. I then setup routines in Amazon Alexa App and left instructions for the kids.[quoted image][quoted image]
Hmmm, I tried to set that same scene up and it doesn’t work for me. Any tips?
Quoted from djreddog:Hmmm, I tried to set that same scene up and it doesn’t work for me. Any tips?
It's not a scene... it's under routines. But first, make sure you've enabled the "smart home skills" for the device you want Alexa to interact with if you haven't already done that.
Then, once Alexa can control the device(s), go to the Routines page in your Alexa app and hit the + and then start following the setup. "When this happens"... choose Voice and then type your command like "let's play pinball".
Then you can go through and add actions to turn on your switches. Add delays or voice responses with the "say" function. Have fun and let us know if you get it working.
I first setup the plugs in the smart life app and named them accordingly.
While still in the smart life app I created 2 scenes. One to turn the games on and one to run them off. I added 2 second pauses between each game to now blow breakers in my house.
Then in Alexa app I added the smart life skill and scanned for devices. I then setup the routines to use the scenes from smart life app.
Pictures should make it clear.
066AE79F-56D1-4F36-8B17-DFFF5B45F9A2 (resized).pngEDCA6AB7-3BE9-4D71-ADA4-1497FDB5EB0C (resized).png1269401E-FBC9-44F2-880D-CA21BAE5303F (resized).pngQuoted from Bos98:I use Gosund plugs from Amazon. 4 for $25 on sale fairly regularly. I then setup routines in Amazon Alexa App and left instructions for the kids.[quoted image][quoted image]
They do make power strips now as well
My last CE Smart Plug just went, had it on my AC/DC Pro a single pin is more than they can handle. I switched to the receptacles and they are working great. Take a little more effort because you have to replace the actual plug but way better.
Quoted from dondon4720:They do make power strips now as well
https://www.bestbuy.com/site/geeni-surge-smart-wi-fi-6-outlet-surge-protector-strip-white/6306487.p?skuId=6306487
But then I don’t get the tentacle effect I have now, or the APC brand surge protector rated to 1600 Joules.
Quoted from Darscot:My last CE Smart Plug just went, had it on my AC/DC Pro a single pin is more than they can handle. I switched to the receptacles and they are working great. Take a little more effort because you have to replace the actual plug but way better.
A little late since you upgraded anyway, but this could have worked too...
DonDon - I'd be a little leary of the Best Buy plug mentioned. It is rated for 10A, but it doesn't address power factor (i.e. the relationship between current and voltage). Sorry - a little geeky, but it does affect current capability. Probably fine tho for one pin.
https://www.thesmartesthouse.com/products/zooz-z-wave-plus-power-switch-for-heavy-duty-appliances-zen15
Quoted from mbwalker:A little late since you upgraded anyway, but this could have worked too...
I use the ZEN25 for my machines. I have 9 of them and haven’t had any issues. They are a little “chatty” and bog down the network, so you need to make some adjustments to their reporting frequency.
Keep in mind, that the Zooz line is Zwave and everyone here is discussing WiFi.
Quoted from Spyderturbo007:...Keep in mind, that the Zooz line is Zwave and everyone here is discussing WiFi.
Good point, I read right past that!
I think the newer of Alexa versions support Z-wave, but it might be thru an external device (e.g. Samsung SmartThings which I use, etc.). Not necessarily built it. Ditto for Zigbee.
Quoted from mbwalker:Good point, I read right past that!
Alexa needs a Zwave controller.
Quoted from Spyderturbo007:Alexa needs a Zwave controller.
I tend to agree. I read a while ago that the Echo Plus might have one (actually, I think it was Zigbee), but not sure if I trust the posting... I doubt if the Echo Dots would have either, given the low price point.
Anyways, didn't mean to sidetrack the OP w/Z-wave.
This page was printed from https://pinside.com/pinball/forum/topic/wifi-enabled-smart-plugs/page/2 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
