Hi all,
trying to buy my first pin. New to the hobby, been playing a lot of virtual pin but want to learn real nudging. looks like I can get a very good deal on a Wico Af-tor machine but I need to get it working first, the current owner is letting me work on it at his house before buying it.
First off, Here's the operator's manual, including schematics: http://mirror2.ipdb.org/files/25/Wico_1984_Af_Tor_Manual.pdf
when I reference the manual I will use the page numbers printed on the page corners, the PDF page is always 3 numbers higher.
Ok. So when plugged in, all I get is general illumination. (http://i.imgur.com/WfWbrKo.jpg) there were 2 blown fuses that have been replaced and still the same situation. The diagnostic LED digit display and all other displays do not come on. I believe the control board is not getting power. The diagnostic LED digit display at the bottom of the control board does not light up: http://i.imgur.com/3ZtxnUP.jpg this is mentioned on page 5 of the manual.
So First thing is to get the displays working. I replaced 2 blown fuses (Identified by visual inspection + corresponding LEDs being out) Still no luck.
So looking at the troubleshooting section, on page 41, stepping through the "No Display" steps I checked #1, F5 LED is good. #2 says to check the F7 LED but F7 and F8 BOTH seem to have NO LED! at least not that I can see... I replaced both fuses anyway, and am still in the same state of things. There is one, very dim LED on the opposite corner from the fuses
Pics of the board, no flash to show LEDS: http://i.imgur.com/qVLV1YC.png
Flash to show Board: http://i.imgur.com/p1IP6GW.jpg
#3 gives instructions for If the RED LED is on and there is a C on the test display. The RED LED is on but nothing on the test display.
I'm going back to his house on Saturday with a voltmeter. What should I be doing as my next steps?
thanks for reading. Help me Obi-pin kenobi, you're my only hope.
