(Topic ID: 192348)
Why you need a spray booth for painting
By uncivil_engineer
2 years ago
  • 18 posts
  • 11 Pinsiders participating
  • Latest reply 2 years ago by fordtudoor
    There have been 8 images uploaded to this topic. (View topic image gallery).
    #1 2 years ago
    So last night I painted my first cabinet using a HPLV setup. Things didn't exactly go to plan.
    This is not my first rodeo with a spray gun. I have been using an airbrush for year. I've done lots of scale models using water based acrylic and oil based paints. Typically I run my airbrush at around 20 psi and overspray is never really a problem.
    I thought I had planned out my first HVLP adventure pretty well. My shop has a 10 foot wide sliding door that leads to the back yard. I figured I could open that door to vent the shop, and only have to cover up the work bench nearest the door, and the wall on the opposite side of the door. To create an outward breeze, I put a fan into one of my windows in the shop blowing inwards. To protect the floor, I put plastic down under my spray area.
    Well things didn't turn out like I'd hoped. Instead of the fan creating an outward breeze, it created more of a swirling. The HVLP gun put out a lot of paint, and that created a bit of a problem for my shop floor. Lucky for my, the floor was not pretty to begin with, but now there is a definite line where my drop cloth was. Moral of the story: Buid a paint booth! I wish I had.
    BTW, the cabinet came our alright. I only had a run in one place.
    #2 2 years ago
    Your going to need a stiff broom, and possibly a mixture of water and TSP, to get that overspray off the floor. Scrub the solution in a small area first, to see if it will lift the paint off. Then wipe up, or wet vacuum up the slurry. Not sure of your set up, but spreading solvents on a floor can lead to hazardous fumes, which can enter your home or fumes being ignited by a flame source.
    Knew a guy that painted his Mustang in his garage. Everything in the garage ended up with a fine layer of red overspray. Shovels, lawnmower, car parts, tool box, posters, books... etc. The paint job looked fine, the garage interior, not so much.
    #3 2 years ago
    I have a jurassic park ramp that someone got spray paint all over. They had made a plastic, but decided they wanted it to be green, another plastic was to be black. So they painted the plastics while installed in the machine. So now black flecks are over a decent number of components.
    #4 2 years ago
    Whoa yeah...thanks for the info. These are the exact shannigins I find myself getting into.
    #5 2 years ago
    Quoted from Darcy:
    My shop is separate from the house, so if I wanted to spend a fortune cleaning up the floor, I could use solvent. What is TSP? and where do you get it?
    Thanks,
    --Alan
    #6 2 years ago
    Quoted from uncivil_engineer:
    Tri-Sodium Phosphate, most hardware stores or paint sellers should have some for sale. It is a powder (or can be premixed), that when mixed into water can be used for cleaning paint brushes. Especially useful in cleaning walls before painting, or used to clean a surface after a solvent has been spread on that surface.
    Again, not sure if the TSP will work, but it is not too expensive and your floor will be clean, but possibly still have some purple.
    #7 2 years ago
    Tsp is a mild etcher as well. We use it to clean and prepare floors for concrete sealers and light foot traffic floor coatings. It is a good cleaner and will lift a lot of lightly adhered overspray. Was the material sprayed latex or a solvent borne product? Latex with tsp mix led with hot water and a stiff bristled broom should lift of latex no sweat.
    #8 2 years ago
    Unfortunately the paint was single stage automotive paint. I imagine it may take lacquer thinner to get it up.
    #9 2 years ago
    Yes, lacquer thinner will need to be used. You could use a lower grade lacquer thinner, some companies call it 'Gun Wash'.
    #10 2 years ago
    why not just spray outside?
    #11 2 years ago
    Quoted from Jjsmooth:
    The rest of the world takes a bit more care than Cincinnati.
    #12 2 years ago
    If you like dust and possibly bugs embedded in your paint job, have at it
    #13 2 years ago
    Why not just shoot some overspray over the clean area and call it a day...
    #14 2 years ago
    Quoted from cosmokramer:
    a proven method lol...
    #15 2 years ago
    Quoted from toyotaboy:
    He had a fan in the window blowing inwards...
    Besides, most finishes flash off in 5 - 10 minutes.
    No reason for a non professional to create an unnecessary mess for himself.
    #16 2 years ago
    Quoted from TheLaw:
    I have my own custom cabinet and furniture shop. Been in business 25 yes. I probably know how to take care with what I do. Maybe even moreso than you.
    This was a first timer who had a preventable bad experience. I would hope he tries again, and maybe that helps.
    Also, in an enclosed room, using an hvlp gun, the fine atomization of paint in the air dries before falling on the wet paint applied, resulting in a sandpaper feeling.
    finish.
    Just trying to help. Good luck, op.
    #17 2 years ago
    I found out the hard way like you you need an external paint booth. I also found out ...the hard expensive way that not making it properly also costs more.
    So eventually I made this. I erect it every time I need to spray a cabinet or play field.
    Here is a pinside link. https://pinside.com/pinball/forum/topic/making-a-collapsible-pvc-paint-booth#post-3634101
    #18 2 years ago
    I learned my lesson a long time ago. I spray painted an item at the end of the driveway, almost into the street. I couldn't believe that the overspray carried into the garage and landed on the wife's car. That's when I decided to build a paint booth. It is 7 feet by 8 feet by 8 feet tall. The floor, roof, and sides are 6-mil clear plastic over 2x4 frames. It is portable as all the studs are bolted together. It is better to have ventilation that is induced draft as opposed to forced draft. I have double 3M Filtrete filters limiting the dust being sucked in and boxer fans/ductwork in the ceiling that vent the fumes outside the house. I found from experience it is better to have the flow of air across the back wall of the booth as opposed to have it flow over the article you are spraying. Indy cabinet turned out perfectly with no dust whatsoever in the paint finish.
    $ 48.00
    $ 12.00
    $ 79.95
    $ 7,499.00
    Nitro Pinball Shop
    $ 689.00
    $ 40.00
    G-Money Mods
    $ 45.00
    $ 5,999.00
    Great American Pinball
    $ 29.99
    $ 45.00
    Pinball Mod Co.
    $ 79.95
    $ 48.00
    $ 9.95
    $ 29.99
    £ 29.00
    PinballToys
    Pinball Photos
    $ 18.99
    $ 24.25
    The MOD Couple
    $ 2.00
    Doc's Pinball Shop
    CzTV Mods
    $ 49.00
    Pixels Arcade Games
