Quoted from ThatGuy:I hear you, as I have a set that I have yet to install on my SST as well. I need to take off the ramps and replace a couple of GI lights as well. I saw your pics of your SST. Looks good. Any suggestions?
Well, make sure that cliffy fits tight up against the front of the live assault range hole, even if you have to modify the mounting holes to let it get there. I figured the hole was large enough that the tiny bit smaller opening wouldn't matter. I was wrong.
There is a flasher under the plastics behind the Live Assault target. I would replace it with an LED as there isn't a good way to get to it to replace it without tearing it all down.
I'd also replace all the GI lights in that area with LED's, as you can't get to them from the bottom to change them. If you have a thing against LED's, I would at least put new bulbs in there.
For inserts, either buy the premium non ghosting, or expect a lot of ghosting. I'm ok with a bit of ghosting, but this pin ghosts more than I am willing to accept. The upgraded bulbs would have been a good idea.
Lastly, the plastic ramp really isn't that bad. It comes off in one piece, all toys and flasher assemblies still connected. Number the connectors under the playfield so you can easily put them back together later.
