(Topic ID: 52969)
WHY not? An ongoing Revenge from Mars Restoration
By Whysnow
10 years ago
  • 87 posts
  • 29 Pinsiders participating
  • Latest reply 10 years ago by Taber
  • Topic is favorited by 12 Pinsiders
There are 87 posts in this topic. You are on page 2 of 2.
#51 10 years ago
Wow! Have fun on the harness swap.
Jeremy Agema
Central WI
#52 10 years ago
Quoted from PM_Jeremy:
Jeremy Agema
Central WI
It is one of the scary parts but also very fun. A mess of spaghetti.
I take a bunch of photos, then take everything off and take the whole thing to the tub. I leave on all switches and sockets. Any bigger cherry switches (none on RFM) would get taken off because they could hold water.
Awesome orange does the work along with a scrub brush and LOTS of water to rinse afterwards.
Then off the the air compressor to blow the heck out of everything really well.
Finally I let her air dry for a while and then reinstall.
#53 10 years ago
good feeling.
After finishing the burbon and 2 turkey meals I was able to get all the remainder of the top side flipped over.
#54 10 years ago
a few glamor shots
tried to use the macro feature on the camera...
#55 10 years ago
also, to give you an idea of how bad this game was, check out the original popper and the metal cover on the VUK...
the metal cover is actually misshapen/ humped out from so many balls being popped through it over the years at CEC.
#56 10 years ago
Amazing! Great photos - good use of the macro function.
#57 10 years ago
The past few days have been pretty productive. Big thanks to Corey for some needed RFM intel along the way >> I am sure you are sick of me calling/texting to ask questions of how it is supposed to be This game was so hacked! The deeper I dug the worse it got.
Harness pulled off the old.
I like to use a piece of pink foam to transport the harness around. Makes it easy to move and keeps stuff in its general spot.
#58 10 years ago
I take the harness to the tub and spray it down with 'LA's Totally Awesome Oxygen Orange' degreaser. You can find it at the dollar store and it works like a charm with no corrosion or residue. I use a stiff nylon brush to get between the cracks and wires and of course rinse liberally with water. The funk just melts away.
Then it takes me about a day to put the bottom side all back in place. Quite a few issues i discovered along the way like missing diodes or diodes on backwards. Note: never trust that just because a game came to you a certain way that it is correct.
#59 10 years ago
Only a few things left to do on the bottom. I am waiting on the missing coil wrappers from BAA, which they ended up mailing out on Friday. I also have a few coil rubber grommets that I need to replace when the marco package comes in later this week.
For all intents, the pf is now done.
If anyone is in need of any part leftovers or interested in the old pf then hit me up. I am not sure on pricing for anything but the pf is just a wall hanger. A pro could likely restore with a nice decal and then clear coat for the inserts that are missing art. Ramps are all functional with some cracking >> I just go all the way and spend way too much money so I 'had' to replace them with NOS. I know it is silly, but I accept it
#60 10 years ago
Quoted from Whysnow:
That RFM looks so clean&purty, I cant wait to put something on it and get my own "glamor shot"
#61 10 years ago
Nice progress! Looks like it's getting close to done.
I've got a HUO RFM here that's pretty clean; if you need any help figuring out where anything goes as you put it back together, let me know.
#62 10 years ago
Been busy the past week...
#63 10 years ago
Almost have the cab back together post paint.
I set up a temp spray booth in my garage this past week with a portable heater. It is the one thing I do not like about winter in WI, Cab work is a more complicated process.
I have a few more things to work on, but with any luck the cab will be completely back together by the end of today.
Ordered T-molding finally as I complete forgot about it till now.
#64 10 years ago
I never realized the boards for these games were in the bottom.
Looks very nice - we have discussed this before - how long does it take for you to solder everything back on? I always take everything off the pf as one unit rather than seperate the harness.
#65 10 years ago
Resoldering everything took me probably 4 hrs in total? But that also includes messing with switches and similar stuff. This one also took a bit longer that FT because so many things were messed up from the operator back in the day. I spent a decent amount of time just making sure I had diode on everything and correctly orientated as may were missing or backwards.
#66 10 years ago
Looks awesome! What did you use to fix the scoop? And what method to clear?
Keep up the good work!
#67 10 years ago
4 hours isn't too bad at all. Maybe on my next one I will make the attempt to remove the harness. I usually clean it right on the PF.
How many diodes are wrong do you usually find? If they are backwards or missing - how did the game still function?
#68 10 years ago
I have no idea how the game was still functioning but it was. I had turned it on when I got it and everything 'worked'. i will admit that flipping the switch on this one is going to be very scary and I am trying to mentally prepare for some degree of issues...
This pf repair is using all the vid methods (to the best of my ability) and then had ssbodyman clear this one with 2 part auto..
#69 10 years ago
Well - it's going to be sweet when it's done that's for sure! These games were the pf is switched takes a hell of a lot of time. Think I'll avoid projects that require a pf swap in the future...
#70 10 years ago
Nice work. Hope it turns on perfect for you.
#71 10 years ago
Quoted from Methos:
I was wondering the same thing. A game can still function with missing diodes (with a much higher chance of damaging the transistors with high voltage inductive kickback), but backwards diodes should blow a fuse, unless the diodes were backwards and already blown open. You might want to make sure the connectors to the pcb are still wired correctly if this game has had as much abuse as you describe...
Hopefully it will be fine when you power it up.
#72 10 years ago
From the looks of it my guess is that the ones that were on backwards were toast and effectively gone/blown open? I have gone through the entire came following the manual to make sure I am putting it all back together as intended rather than as the CEC 'technicians' had it done.
I am guessing it was not really functioning at the end of its route life since the flippers were not really playable.
#73 10 years ago
Quoted from Methos:
Not sure if this is what you meant; the computer is in the head, the power/relay board is in the bottom of the cabinet.
#74 10 years ago
It is ALIVE!!!!!!!!!!!!!!!!
Plays VERY fast!
I still need to do a few adjustments, but it is actually working!!!!PC080356.JPGPC080356.JPG
#75 10 years ago
Also, anyone have good LED recs?
Do I need to worry about ghosting?
I was thinking of frosted warms for the GI and frosted color matching for the inserts. Keep the flashers standard.
#76 10 years ago
Side note > If I end up keeping the regular monitor, I noticed quite a bit of bleed over from the florescent tube in the back box. I am guessing there is supposed to be some sort of foam around the monitor to block out and light coming through?
What have others used? Just pipe insulation?
#77 10 years ago
Man - you work fast! I've spent all weekend putting the posts and ramps back on my Diner!
#78 10 years ago
Keep a fresh supply of balls near the machine. By painting the whole inside of the lower cabinet, your balls will rust out about every month or so.
There's a reason they weren't painted from the factory. Wood absorbs moisture won't when painted. So moisture finds its ways to metal things - especially balls.
Telling you from experience.
#79 10 years ago
Not sure it's the best value, but I installed the below kit. No issues with ghosting or other lighting issues, except the usual error from P2K because it doesn't think the lamps are working...
http://www.pinballcenter.eu/catalog/revenge-from-mars-noflix-plus-playfield-kit-p-636.html?language=english
#80 10 years ago
Quoted from dgoett:
I have not experienced that at all with my fishtales and I did that almost 9 months ago. I even did more coats with that game so it is sealed even more.
I am guessing the reason only the top half was painted from the factory is because it was a labor and material savings???
#81 10 years ago
I also did this on my last restoration which was coincidentally a FT too. Never heard of the rusty balls problem either (heh heh).
Although my my basement is pretty dry so it would be a slow process for me. If this was ever an issue you could always buy a small silica gel dehumidifier and toss it in the game. I have a small one for a gun safe that you can plug into a wall socket to recharge.
#82 10 years ago
Yeah, if anything, sealing the wood will mean less moisture inside the cab IME.
Also, there are some really big vent/speaker holes in every cab I won so I should be OK
#83 10 years ago
When I had SWE1 I had to put a new monitor in and found that sealing it in with black gorilla tape worked perfectly.
And I the cured the light bleed from the gap between the playfield backside and cabinet with thick foam weather stripping. I still have some and can bring it on the 28th if you want.
#84 10 years ago
Thanks. I used some pipe insulation and is seemed to work.
Looking forward to the 28th!
3 weeks later
#85 10 years ago
Hi
Great job on the restore project!
I am doing a little restoration on my RFM and had a question that hopefully you can answer. I need to remove the pop bumpers to replace the wafers, but can't seem to figure out how to remove the ones with the lights in them since the flat silver wires are stapled to the bottom of the playfield. Do I need to cut the wires and re-solder or is there another way?
Taber
#86 10 years ago
you could desolder, but I think that is a part worth replacing.
Cheap and easy. If you are unsure of your skills, just do one pop at a time. I cut and leave the leads stapled so I can see where to restaple the new ones upon reassembly.
Worth mention to plan your attack on which pop to do first (really easier to do all 3 at once) as space is tight, esp if you have big fumble fingers like I do.
http://www.pinballlife.com/index.php?p=product&id=1245
#87 10 years ago
Looks like that is the plan.
Taber
$ 85.00
Gweem's Mods
$ 11.95
$ 5.00
$ 84.99
FlyLand Designs
$ 46.99
Lee's Parts
4,000 (OBO)
Milan, PA
$ 79.00
PinballReplacementParts
$ 1.00
Pinball Alley
$ 8.99
Inscribed Solutions
$ 95.00
Pinball Mod Co.
KAHR.US Circuits
7,500 (OBO)
This page was printed from https://pinside.com/pinball/forum/topic/why-not-an-ongoing-revenge-from-mars-restoration/page/2 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
