(Topic ID: 145723)
Why has no one developed a better way to level a pin?
By cooked71
  • 60 posts
  • 32 Pinsiders participating
  • Latest reply 4 years ago by cooked71
    There have been 6 images uploaded to this topic. (View topic image gallery).
    There are 60 posts in this topic. You are on page 1 of 2.
    #1 4 years ago
    After reconfiguring my games room tonight, I had to also re-level all my games as I had moved machines from one wall to another.
    Another 1/2 hour crouched under the games leveling the legs. Now my back is killing me.
    It's got to be one of the most annoying parts of owning/operating a game, yet leveling is also the most important part of setup. Must be a huge pain for operators.
    Why has no one developed a better leg leveler system? (I know.....cost).
    A simple idea such as having the bolt from the levelers extend all the way up the legs. Then having some sort of screw mechanism where they could be adjusted with an Alan key from the side. Or like a dishwasher that you can adjust all the levels from the front using an Alan key.
    Or having the playfield itself adjustable.
    Has anything new ever been tried?
    #2 4 years ago
    There used to be several ways, including using a drill. Very easy. Wish I could remember more but it's late
    Here it is, sold out for years
    http://bayareaamusements.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=PL-ZIPLEV
    #3 4 years ago
    You shouldn't have to lift anything with your back. You can turn the bolt with a wrench, lifting the machine on its own.
    You turn the bolt downward, closest to the floor, and only spin it backwards, up to the leg, once it's level, then tighten.
    Make sense?
    #4 4 years ago
    Is there a level or Inclinometer that talks, beeps or farts giving you information that you can hear while under the machine?
    #5 4 years ago
    Quoted from pinballdork:
    Pin Guy on iOS. There's a similar app for Android (might also be pin guy or Pinball Leveler, something like that). Tells you "Left 0.3 degrees too high, back 0.4 degrees too low" every few seconds.
    #6 4 years ago
    <blockquote cite="#2828977"Must be a huge pain for operators.
    Yeah, that is top of the to-do list for operators.
    10
    #7 4 years ago
    Quoted from DefaultGen:
    Almost cracked my head open when I was using this app, got the machine set perfectly and the app repeatedly told me so and then stated something like: "really, you can crawl out from under the machine now" - laughed so hard, forgot where I was and THUNK!
    Love this app.
    #8 4 years ago
    I'd love to see small electric motors you could quickly secure to each leg that would interface with bolts via gearing. Maybe 20 to 25 per leg. Then Bluetooth control to phone app or direct wire to couple buttons to control them. Nothing ops would buy but I'd invest for small home collection. I hate leveling manually
    #9 4 years ago
    Leveling manually does suck, but I found a way to make it easier so I don't have to use my back or wrenches. I bought a cheap hydraulic table lift from harbor freight and I use that to jack up the machine so no legs are on the ground, and then adjust nice and easy. I use this in combination with pinguy app on iOS to know which ones to adjust.
    Nice thing about the lift is that it makes a great portable service bench that you can move around to each pin to hold all the tools and parts while you work on a machine.
    10
    #10 4 years ago
    Quoted from Chambahz:
    Make sense?
    But it's sooo much easier (at least I find it is) to loosen the locking nut (if one is installed) lift the entire machine on your back because it's not that heavy on all fours, and then spin the leveller with just your fingers.
    #11 4 years ago
    MAGIC SLIDERS! Then you can just twist the sliders to adjust each leg, no tools or back strength required.
    #12 4 years ago
    Either you should trade in your back for a stronger one or you could try double nutting the levelor shaft at the top and this will allow you to turn them without lifting the machine.
    #13 4 years ago
    You can use pinball skates as a lever to lift the legs up a bit, adjust, then set them back down. I'm all for a magic system of servos that makes a perfectly level, 6.5 degree playfield, but once adjusted and locked in for home use you don't have to re-adjust too often
    #14 4 years ago
    Get a lift cart from Harbor Freight. I eyeball level when I lower the pin, then I make fine tuned corrections with the assist of my lift cart. Raise just enough to lower or raise castors.
    How do you move your games?
    #15 4 years ago
    I believe Gerry has with the P3, unless I'm mistaken.
    #16 4 years ago
    What I think would be cool (and simple!) is a couple accelerometers (or tilt sensors) on the playfield and a system in the menu that tells you which leg needs to go up or down for level and what your pitch is at. If an iphone can do it, surely a pin can.
    #17 4 years ago
    I just eyeball it when I setup the game, before even putting the legs on. I judge the pitch of the floor visually, and adjust the levelers accordingly. Comes out perfect every time! Duh...
    #18 4 years ago
    Quoted from dsuperbee:
    Thats kind of what I was thinking - but looks like its not available.
    I use Pin Guy app - invaluable.
    Quoted from JoeGrenuk:
    Sarcasm? Sorry. I forgot. Most operators couldn't be bothered levelling their games.
    Quoted from Mbecker:
    That would be awesome. Id definitely be in for a set.
    Quoted from Toasterdog:
    I have 1/2 my machines at home and 1/2 at work. I have a lifter at work where we have concrete floors and I use that for levelling. At home we have wooden floors which are quite soft. Any type of lifter damages the floors. I have rubber feet under the legs that have felt under them, so I can slide the games to move them.
    Quoted from o-din:
    Tried this and it works, but my back legs are at absolute max extension, so I have to remove the top nut. (And that's with the long 3" Levelers).
    I still don't think it would be too hard to improve the existing system. Obviously cost is the big issue - but technically it's really simple. I guess if pinball was bigger, there was more volume, and more competition, it would have happened already.
    #19 4 years ago
    Yes, you can set this one to beep at a preset angle. it works pretty decent & it's small enough to be useful.
    amazon.com link »
    #20 4 years ago
    Quoted from cooked71:
    Have to admit I assumed the nuts were for locking the levellers
    They are. But if you lock two nuts together then you can put a wrench on one and turn the leveler .
    #21 4 years ago
    Quoted from o-din:
    Tried this and it works. But my back legs are at absolute max extension, so I have to remove the top nut. (And that's with the long 3" Levelers). Can you get longer Levelers?
    #22 4 years ago
    The nut(s) goes between the leveler and the leg.
    #23 4 years ago
    Quoted from johninc:
    On the back ones yes.
    #24 4 years ago
    there was a dude on RGP developing a leveler that used a drill to raise and lower - looked cool
    #25 4 years ago
    I'd like to see a friendly robit that picks up the game, talks to a phone placed on the pf, adjusts the level just so, then waits for you to adjust the levelers down to the floor before retracting.
    #26 4 years ago
    Quoted from DanQverymuch:
    That's pushing it a bit too far. Really, does the robot need to be friendly?
    #27 4 years ago
    I actually added self leveling mechanisms that are sold for washing machines to some legs...it worked fine, but looked Ugly.
    Not enough of a market to re-engineer.
    In checking, here is something new that I havent seen:
    #28 4 years ago
    I use a flat pry bar under each leg, one at a time, to assist with the weight of the machine. Pry off the ground and spin the leveler in or out by hand easily. Set it back down and check if it's good, pry and adjust again if necessary.
    #29 4 years ago
    Quoted from jkroeck25:
    That's a good idea. Going to give that a go.
    #30 4 years ago
    Quoted from OLDPINGUY:
    That's the kind of thing I was thinking of - but you're 100% right - the market is not big enough. Adapting washing machine Levelers is probably as good as we'll get - same concept bigger market. Having said that, the pinball collector market are more obsessed and have deeper pockets than the average washing machine collector.
    #31 4 years ago
    Quoted from shlockdoc:
    Where is this dude now? Wonder if that's the one from the first link to Marco:
    #32 4 years ago
    This guy will level your pin for you if you're not too picky.
    #33 4 years ago
    "Friendly robit" is a Mr. Show reference. Now get off my land!
    #34 4 years ago
    If only there was something everyone would need atleast 4 of ... i'd be a rich man! hmmm brb :p
    edit: I have some nasty old scratched pinball feet at home. Might have to try out an idea.
    #35 4 years ago
    My Craftsman "Smart Tool" level beeps. Most of the newer electronic ones do.
    It levels the incline plus the side to side all in one shot. I always remove the playfield glass and place it directly on the playfield for the ultimate in accuracy.
    #36 4 years ago
    Mr Show? Never heard of it. You Americans and your 4000 TV channels.
    #37 4 years ago
    I get this.
    #38 4 years ago
    Aside from flies as large as cats do you Aussies also have to suffer with no HBO?
    #39 4 years ago
    I get a bunch from my Mate in Cairns, Aurich!
    #40 4 years ago
    Quoted from westofrome:
    Yep this is what I do. I use the small units about the size of the feet. Works perfect, especially on carpet
    #41 4 years ago
    Quoted from Aurich:
    Yes and no. HBO specific shows (ie. game of thones etc) are now on foxtel ( https://www.foxtel.com.au/watch/gameofthrones.html ). Other shows *might* be carried by other streaming services.
    One of the reasons Aussies were the biggest pirates of American TV shows.
    #42 4 years ago
    Quoted from Aurich:
    No HBO, but Foxtel (our main pay TV provider) gives us some of the bigger shows.
    However, it's possible to use Apple TV with a US account. Until recently, you could also get US Netflix with DNS re-direct. Not sure if it's still possible now NetFlix has set up here.
    #43 4 years ago
    He was in my backyard yesterday
    These are the ones you need to worry about (and they really are in my backyard) Red Backs and Funnel Webs:
    Especially when you are leveling your pins, because thats where they hide. And it's why we need a better solution.
    #44 4 years ago
    Quoted from homebrood:
    #45 4 years ago
    Yikes! Move!
    Your Crocs and Snakes are worse
    Flat in Florida...never have to level a pin!
    ...or maybe I just tilt a little.
    #46 4 years ago
    Ohhhh...one of the MANY reasons NOT to live in Australia.
    #47 4 years ago
    Damn, I want to flag those pictures, f—king spiders. What we have now in SoCal are Brown Widows, they came over from Florida, and have apparently been killing off the Black Widows and taking their territory. PITA spiders. Webs are tough as steel too.
    Brown Widow
    If Peter Jackson had wanted to make Shelob the way I would love to have seen her, she would have been smooth, and black, and shiny, with an awesome skull shaped red patch. Your Red Backs and our Black Widows, prime examples.
    #48 4 years ago
    I looked at that design for a while and looked to see if I can replicate it. Didn't seem much to it on first glance.
    My getto solution is another nut of the same size. This puts an extra spare nut at the top of the threading. Get two spanners and force the two nuts to lock into each other. I couldn't find a locking nut at bunnings so I just used an extra which would do the same job just so I could test it out.
    I used a flexible drill extension plus a socket adaptor.
    http://www.bunnings.com.au/craftright-280mm-flexible-quick-drill-extension-_p6320510
    socket adaptor
    http://www.bunnings.com.au/craftright-3-piece-socket-adaptor-set_p6320452
    add on the socket itself and give it a go.
    The main issue is that the BAA ones use special feet. Stock ones have a square rod base where it goes into the pressed steel footing. The problem here is that normal ones will spin the entire foot if the rod is turned. You can see this happen in my video.
    In my case I have carpet protectors under the feet of all my pins anyway so they just spin in place on plastic so its not an issue.
    So tried it again on feet with the entire pins weight on it. Maybe the double nuts would come undone.
    Nope! Worked like a charm!
    Just need to hunt down some locking nuts now!
    #49 4 years ago
    Quoted from koops:
    socket adaptor
    Thanks Koops! Off to Bunnings this weekend to test it out.
    #50 4 years ago
    Quoted from Aurich:
    Brown Widow
    Those Brown Widows look almost the same as Red Backs. Turns out they're the same Family and you guys exported some Brown Widows here also. Thanks!
    http://www.qm.qld.gov.au/Find+out+about/Animals+of+Queensland/Spiders/Modern+Spiders+Infraorder+Araneomorphae/Redback+and+Brown+Widow+spiders#.VmGDLIo8anM
    $ 149.00
    Sparky Pinball
    $ 90.00
    Lighting - Under Cabinet
    $ 39.95
    Little Shop Of Games
    $ 249.00
    Flip N Out Pinball
    $ 22.00
    £ 55.00
    PinballToys
    $ 999.00
    $ 189.99
    PinballBulbs
    $ 199.99
    $ 9.99
    $ 69.99
    $ 12.00
    Hardware
    Tucson Pinball
    $ 149.00
    $ 17.00
    $ 249.99
    Id Rather Play Pinball
    $ 7,999.00
    Nitro Pinball USA
    $ 76.95
    $ 179.00
