(Topic ID: 308078)
Why does dust corrode?
By uncivil_engineer
1 year ago
#1 1 year ago
On my last few restorations, I noticed something. I live in a very dry area (were right off the Mojave Desert), and rust is almost never a problem in games I pick up locally. However I have noticed that the dust I am finding on parts in games has eaten into the finish to the point that it looks like corrosion. Case in point: a roll tilt assembly out of a Firepower I'm working on:
This is the top view. Ive wiped all the loose dust off the part, but the remaining dust has eaten into the plating, and stained the metal. I am going to have to either repaint the part, or buff it out. Has anyone else found a way to deal with corrosive dust besides re-painting/re-plating the part?
Why does dust do this?
#2 1 year ago
Is it salt?
#3 1 year ago
Are you sure the dust is corrosive and not the result of something eating the plating and the dust is left behind ?
#4 1 year ago
I'm pretty sure its not salt.
Quoted from LTG:
I'm pretty sure it is the dust. The plating looks new on the bottom sides of the parts. I noticed this issue on my TAF restoration, and now its showing up in my FP.
#5 1 year ago
Quoted from uncivil_engineer:
Corrosion is the answer, galvanic corrosion. When two different metals are in contact and exposed to a common electrolyte, one of the metals experiences accelerated corrosion while the other is protected. In your example, it’s likely something like copper in the dust that is more noble then the steel or zinc in the other component, which results in the formation of a galvanic cell.
#6 1 year ago
Quoted from PlanetExpress:
This makes sense. It's well known the dust around here contains metals.
#7 1 year ago
Putting this in my learned today bucket.
#8 1 year ago
Quoted from Cmartin1235:
Ditto!
$ 14.00
$ 44.99
Pinball Shark
Shooter rods
$ 36.95
$ 27.95
$ 52.99
Pinball Shark
Shooter rods
$ 649.95
Pin Stadium Pinball Mods
Led
Men
KAHR.US Circuits
$ 11.00
This page was printed from https://pinside.com/pinball/forum/topic/why-does-dust-corrode and we tried optimising it for printing. Some page elements may have been deliberately hidden.
