Hi pinsiders
can You enlighten me ? Do I make a "fault in thinking" ? The first JPG shows the snippet of the schematics of Gottlieb Orbit. Here: https://www.flippers.com/coil-resistance.html I read that the A-5196 Coil has 13R0 Ohms resistance. Other places in the internet I read 13.5 Ohms. When I apply the "Ohms Law" I figure out: 8.15 times Amperes flowing through the 1-Amp fuse. I also figure out: Through the 5-Amp fuse there is 1.63 times amperes flowing.
WHY do the fuses NOT blow when the pin does reset the "Control Bank" ? (8.15 Amperes flowing)
The second JPG I copied from a german site and I have "enriched" it. I read (in german) that the difference in "Fast-Blow-Fuse" versus "Slow-Blow-Fuse" is:
When applying TEN TIMES Amperes through a fuse:
Fast-Blow-Fuse blows in less than 20 milli-seconds (see my 'red circle' at 10 milli-seconds)
Slow-Blow-Fuse blows in 100 to 300 milli-seconds (a tenth to a third of a second)
I also read (in german): Applying (only, lets say) double Amperes, Overload: It will take seconds to minutes to hours for a fuse to blow --- SO: A fuse is NOT good for protecting electronic stuff from "a bit of overload in Amperes". I take this information to my second JPG - a 2-Amp-Fast-Blow-Fuse blows in about 20 seconds when we apply FOUR Amps to that 2-Amp-Fuse (I have made a 'violet circle').
From the first JPG I take: The 1-Amp-Slow-Blow-Fuse must bear a "8.15 times overload" - I simplify a bit and say "8.15 is about 10.00" - I then apply the rule " Slow-Blow-fuse blows in 100 to 300 milli-seconds (a tenth to a third of a second)" and ask You:
The Reset of the Control-Bank MUST (?) be done "within a tenth to a third to maybe a half of a second" ? --- otherwise the fuse would blow ?
And another question - IF (if) we would mount a 1 Amp-FAST-BLOW-Fuse: Would this (Fast-Blow) Fuse blow EVERYTIME when the Control-Bank is resetted (?) --- because (8.15 times is about 10.00 times) the Fast-Blow-Fuse will blow in less than 20 milliseconds - and 0.02 second is less than it takes the Control-Bank to reset ? Greetings Rolf
