Hey, just picked up a Whirlwind. Game turns out, goes into attract mode, and even starts. Once you push the start button, the ball ejects into shooter lane and then game resets. Almost like its tripping a circuit or something. Any help?
Got to be worth a master reset before you start looking right through. Just in case it's got confused.
Most likely something wrong with your
ball eject coil
shooter lane switch
other switch in the trough.
I would look for a short around those moving parts, bad diode on a switch, etc. good luck
Okay, figured out the problem, but not the solution. It is the sound that's causing the game to reset. When I turn down the volume, the game runs fine. My guess is that the game is not getting enough voltage to properly run and the sound just outs it over the top. Any help?
This page was printed from https://pinside.com/pinball/forum/topic/whrilwind-wont-start-help and we tried optimising it for printing. Some page elements may have been deliberately hidden.
