New! Dark mode!
(Topic ID: 261847)
Whole row triggering on my LOTR....Help?
By system11band
9 months ago
  • 15 posts
  • 9 Pinsiders participating
  • Latest reply 9 months ago by Pin_Guy
#1 9 months ago
Long time lurker but I really need some help with my Lord of the Rings.
My third from the bottom row fires all the switches in that row when any switch in that row is hit.
The row stays On for a bit and then turns Off.
It is as if when a switch in that row is hit, it locks on for a good 30 or so seconds and then finally goes off.
I could not find any loose wires when inspecting the switches in that row. I am not sure if the issue is under the playfield or at the boards.
Any help would be appreciated very much.
J
#2 9 months ago
Quoted from system11band:
J[quoted image]
For me on LOTR when I was having switch matrix issues, I found the chip under the battery holder being loose and or along with some green fuzz in the chip socket right under that battery holder to be some of the issue with My game... I had a gremlin in it and did a ton of suggestions to get rid of Switch issues, but have found this Chip to be the area to look at if other areas don't get you to the promise land.
#3 9 months ago
Thanks Coz. I will take a look at it.
#4 9 months ago
J[quoted image]
I had a similar issue In my IJ. Turns out a a switch lug was touching metal....
#5 9 months ago
Reseat the connector on the board for those switches if that doesn’t clear things up then Test the diodes starting with the first switch in that row
#6 9 months ago
Ok I looked at the chips by the battery holder and all look good.
All switch lugs look good.
Re-seating did not help. I cleaned the pins and connectors and no luck either
All diodes are testing just fine as well.
Is there a way to determine if the issue is on the board or in the wiring/switches?
Will post a video as well of the issue.
#7 9 months ago
Ok I got a video of what is happening when I hit one of the switches.
All I did was hit the right sling shot once and let it go. I did not hold it but it is like the switches lock on and then eventually turn off.
#8 9 months ago
nevermind, I see you tested all the diodes
#9 9 months ago
YES!
unplug both CN5 and CN7 which are the switch columns/rows from the playfield
jumper between CN5 pin 9 and CN7 pin 3 - right sling shot
this should tell you if board or playfield related
Cheers Bob
#10 9 months ago
Thanks pinballtoys
Ugggghhhh. Looks like a board issue Any ideas where to go from here?
#11 9 months ago
just to double check that you don't need a diode when jumper between CN5 and CN7
jumper between CN5 pin 9 and CN7 pin 5 and check you only get a single switch made, #61
maybe checkout U400 (LM339), schematics in manual
cheers Bob
#12 9 months ago
had a similar issue with a different machine , ended up being the transistor was blown , check the resistance of the u401 transistor for that row, if dramatically different from the adjacent ones it needs replacement .
I think I recall this to be true but are the 2 switches on column 4 a normally closed status?
#13 9 months ago
delete
#14 9 months ago
okay, so definitely on cpu board and not play-field
checkout U401 (LM339), schematics in manual
if it were my game/problem i'd change U401
part of it reads row 6 (CN7-P3)
its possible the right slingshot coil voltage may have connected to this switch row!
cheers Bob
#15 9 months ago
Quoted from pinballtoys:
you wouldn't as you are only driving a single row with a single column.
$ 16.00
$ 54.99
