Well I dread posting this knowing there are other threads, but I really could not find any that addresses my issue.
The slot reels are stuttering. (Attached vid)
- I checked the reels and validated they were not spinning on the motor shaft. I mad a mark on the shaft to ensure it wasn’t the reel spinning on the shaft. Hard to see in video buy it validated it’s the motor. (See vid)
- I also pulled the motor rotor out to look for metal shavings and did find a lot
- I also notice there was some sort of maybe brass bushing in the middle of the rotor. (Attached pic)
- it seems to be falling apart, only a few pieces left. I am not exactly sure if it’s a bushing.
- looking for ideas on how to repair it and even if it’s a busing.
- I did check the i out voltage to the three motor control boards, all had 12V
- the output voltage to the motor when activated was 3.8v but it’s pulsing so I don’t think my meter is reading right.
The one I pulled the stator out on and cleaned is now worse than it was.
I know these motors are considered unobtanium, so I desperately want to fix.
I still am not 100% sure what was/is causing the shuddering. Hard to believe all three would crap out around the same time.
Thoughts? Anyone “rebuild” the motors?
