(Topic ID: 267401)
WhoDunIt slot wheel shows wrong image
By redgoat
  • 2 posts
  • 2 Pinsiders participating
  • Latest reply 3 years ago by jarozi
    #1 3 years ago
    The left rotating slot wheel will not match the backglass in 8 out of 10 times. The backglass slot configuration is always correct, but the left slot wheel usually does not match.
    This does not affect the play or scoring but it is annoying. I have switched the positions of the other wheels to the left position but the problem still remains. So the problem is not likely the rotating wheel but rather something else. I've sprayed air around the optos. Anyone else have this problem or know how I might fix it?
    #2 3 years ago
    Do you notice it over-spinning or not stopping perfectly when it should / in sync with the audio? Mine did that, and it was because the slot reel had cracked near the axle so the set screw wasn't holding it securely to axle anymore.
    This page was printed from https://pinside.com/pinball/forum/topic/whodunit-slot-wheel-shows-wrong-image and we tried optimising it for printing. Some page elements may have been deliberately hidden.
