Ok gang got a sample pf in from Wade while the backglass and pf is sent in for Gottlieb quality checks. I figured I'd start with a material ordering guide for building the playfield.
First of all lamp sockets:
qty 16 Laydowns (qty 10 flattened for the DT roving light, 4 for the top rollovers, 2 for the dip target lights)
qty 9 1/4 inch (behind DT, the sides, and the credit light)
qty 7 1 1/8 (4 bottom rollovers, 3 WOW inserts)
qty 11 9/16s (side lights, rollovers, 3 for the center wow target)
qty 4 1/2ths double tab, the inner rollover lanes you cant run a ground braid to them, have to take the ground through the air, I use insulated wire
qty 2 pop bumper sockets, re-use
Roughly 12 feet of tined ground braid
playfield
intem pbr part#
pop bumper A-13905 green qty 2
6 hole skirt A1218G qty 2
drop trarget GTB-DTS-383 set of 10
bumper base B10432W qty 2
lane divider Green –A9394G qty 6
red tent C15646R qty 2
Bullseye target GTB-A9383B qty 1
Pop cap A-20533 qty 2 ('Neutron Star' or A-16883 Ink Spot)'
Ring Kit Team One
Optional playfield depending on condition
playfeld posts qty 43
playfield split posts qty 6
pop ring WLL A4754 qty 2
pins A10542 qty 10
Acorns
arch stick protector 9933
runway shield 8215
ball gate 3290
bulbs 44/47s etc
and then the usual cab parts
shooter trim plate
bolts
locks
legs (out)
cab protectors
levelers
siderail nails (out)
fuzzy side velcro to replace lightboard felt.
And then coils depending on condition, 5141 for the flippers, 4893 for the pops, 9738 for the hold
Other optional items
High current kicker switches GTB-22224+ qty 4 $8.00
Pop bumper switch stacks GTB-B-8549 (corrected)
Screw hardware
I like using stainless steal rather than re-using the old sometimes brittle original, Boltdepot online or even Homedepot as the #6 by 1/2, phillips head, flat head too much of a pain for where it doesnt show.
#6 3/8s inch rollover wires and lamp sockets
#6 1/2 inch for most of the other
Im sure Im missing something else...
