I have been searching for a replacement ribbon cable to go between my BK sound board and speech board. Just haven't had much luck, or anything I've found I'm not sure it is correct. Anyone making these or does anyone know where to buy? Thanks
Reach out to Peter at arcade parts and repair. He made a couple of ribbon cables up for me for different machines that were not necessarily available at the time. Great guy to deal with.
https://www.arcadepartsandrepair.com/
Blake
Quoted from G-P-E:What connectors? Pin count? and Length?
Presume it's this one:
https://pinside.com/pinball/forum/topic/williams-system-6-speech-board-40-pin-connector-replacement
oh. Those...
Unfortunately, that is one that I cannot do. I don't have the correct base plate for my 3M ribbon cable press for that one.
Might want to count the pins but I am pretty sure this is correct @ $17 shipped.
Keep in mine one side is hard soldered to the board.
Quoted from barakandl:Might want to count the pins but I am pretty sure this is correct @ $17 shipped.
ebay.com link
Thank you for the replies. I had seen the Joust one but wasn't positive it was correct although it looked right. Blake at Arcade Parts isn't making them currently. But I just found this one last night right before going to bed.
ebay.com link: Arcade Pinball Williams Audio Speech cable for sys 6 7 and 9 Pinball Machines
I should see it on Monday. Thank you Andrew, having not replaced one before it did look like I will need to desolder the old and solder the new one in.
Quoted from epeabs:Thank you for the replies. I had seen the Joust one but wasn't positive it was correct although it looked right. Blake at Arcade Parts isn't making them currently. But I just found this one last night right before going to bed.
ebay.com link » Arcade Pinball Williams Audio Speech Cable For Sys 6 7 And 9 Pinball Machines
I think I'd prefer the longer one. The tight bends I almost think are part of the reason they fail. Shorter one is cheaper tho.
Quoted from barakandl:I think I'd prefer the longer one. The tight bends I almost think are part of the reason they fail. Shorter one is cheaper tho.
Hoping if the first one lasted 39 years, this one will work long enough.
This page was printed from https://pinside.com/pinball/forum/topic/who-s-making-a-williams-system-7-speech-ribbon-cable and we tried optimising it for printing. Some page elements may have been deliberately hidden.
