(Topic ID: 245272)
Who makes shaker motors?
By Lermods
1 year ago
  • 33 posts
  • 14 Pinsiders participating
  • Latest reply 1 year ago by cp1610
    #1 1 year ago
    Not looking for sellers of shakers, I would like to know who actually manufactures them. I need a bracket, weights and cover for a road show I’m working on. Stern brackets don’t work, but those for Cgc shakers do. Pps can’t help me, already contacted them, Cgc, pinballife and Marco, no luck. Thought I’d try to get to the source if possible.
    #2 1 year ago
    Have you try Homepin? ........ Thunderbird Pinball Manufacture
    His name is Mike
    #4 1 year ago
    How many other Williams games used these shaker motors anyway?
    #5 1 year ago
    Quoted from HHaase:
    Only a few from the factory. However Pinbits did make a shaker motor kit for the W/B games that ran off the flashers. I've been trying to buy one for over 10 years now but they don't make them any longer. Sure wish someone else would make their own version that was triggered by the flashers.
    #6 1 year ago
    Quoted from HHaase:
    Earthshaker? Same part?
    #8 1 year ago
    How hard would it be for someone to make a newer shaker motor compatible with a WPC game?
    #9 1 year ago
    Quoted from Pinless:
    See my above post. Pinbits did make one but they don't produce them any longer. Someone else need to make this.
    https://www.pinbits.com/index.php?main_page=product_info&cPath=13_11&products_id=389&zenid=0c7cf9ed82ced29467be5e89eb6ff9eb
    #10 1 year ago
    Quoted from arcademojo:
    I saw those, and noticed no one has them in stock anymore. I’m sure the market is there. I’m just curious why no one has bothered producing them.
    #11 1 year ago
    Hhaase is making the board. Marco has the motor, just need the bracket, weights and cover. A Cgc shaker bracket should work, just need to source it. The wiring is easy.
    #12 1 year ago
    From what I heard was Pinbits makes them by hand and only make a few at a time. I've been wanting several of these for 10 years and have never seen them available. They also worked with early Stern DMD pins. I've emailed Pinbits numerous times with not even a single response. I would take 3 right now. And more later if they produced them again.
    #13 1 year ago
    Quoted from Lermods:
    Is it triggered by the flashers or by a switch? Interested.
    #14 1 year ago
    It looks like the boards may be available next month (if I’m looking at the right thing)
    http://www.siegecraft.us/presta/index.php?id_product=80&controller=product&id_lang=1
    #15 1 year ago
    In RS it’s triggered during certain modes, like when mb starts. The industry is not interested in helping with this, unfortunately. We as a community need to try to get it done. Pinbits sold their setup for $249, it can be done for about that amount thanks to HHAASE.
    Hhaase (siegecraft) indicated his board will be $30. buy the Marco motor (or the one on eBay) for roughly $89 and then buy a Cgc shaker for about $100. That’s like $220. Take the motor out of the Cgc shaker and put in the Marco motor. You’d still need to do the wiring from the motor to the shaker board and then from the shaker board to the driver board connector. When I get this setup, I’d be willing to make the wiring connections for anyone who wants it at cost, which is like $10 or less shipped. All you’d need to do is solder two wires to the motor. Very simple. Would be cheaper if we could source the bracket, weights and cover, but I haven’t been able to find anyone to help with that.
    #16 1 year ago
    Yes, my board is a remake of the original Williams board, so it'll be compatible with games that already support a shaker via the original code.
    Not the same as the pinbits motor that triggered off the flashers and added shaker effects in other areas.
    I'd look into the motor assembly too, but right now I just don't have the funds for that kind of project.
    -Hans
    #17 1 year ago
    The traditional Stern after market shakers are made in China.
    Can Chris or Melissa be of help?
    -1
    #18 1 year ago
    Have you reached out to Planetary Pinball? IIRC hes got the William's IP ... he would very likely know.
    #19 1 year ago
    Quoted from CLEllison:
    Yes, I reached out to PPS, said they could not help with the board or the motor parts and offered no additional info.
    Quoted from OLDPINGUY:
    I haven’t done that yet, I was planning on doing that.
    #20 1 year ago
    I would buy a few that ran off the flashers. I also can't believe nobody has made them. There seems to be enough demand
    #21 1 year ago
    Quoted from Butch2099:
    I think Pinbits made two different ones. Ones that ran off flashers and ones that ran off a switch hit.
    With games like MM, AFM. STTG, Stern POTC These would be great on. And I'm sure there are many other games that a shaker would work nicely with.
    #24 1 year ago
    My boards are finished and in production. Going to ramp up a bit slow till I get a feel for demand.
    They definitely fit Road Show and I believe also Harley Davidson. But NOT
    Earthshaker.
    Earthshaker boards have a different layout and pinout. I could do that one too but need a photo of how they are mounted. Need to sort out if I’d want to keep the same heat sink as the later boards or use the original ES style layout.
    #25 1 year ago
    So I was planning to wait until we were further along to make an announcement but after seeing this thread I feel compelled to do so now.
    We have been developing a universal plug and play shaker motor kit for several months. We have done an extensive amount of research and development and have a couple prototype boards we are currently testing. The motor can run off of flashers as well as pop bumpers and will be compatible with just about any machine that have either. Testing has gone very well with all WPC era machines and older Stern SAM systems that were made prior to them including shakers from the factory (POTC for example). We are still trying to get them to work with Williams System 7-11 series as well but we havent gotten the results we are happy with yet. It should also work with Gottlieb, Data East and Capcom generations but have yet to test them. It will also have up to 8 differnet inputs that you can select with an on board dip switch so you can choose to have more than one flasher triggering the motor.
    The entire kit is going to be plug and play, no wire splicing or soldering required. The most invasive part will simply be drilling the holes in the bottom of the cabinet to mount the motor. The kit will even use it's own power supply so there will be no need to draw power from the machine's power driver board. We have developed a way to easily tie the separate power supply to the machine's 110vac so that it will turn on/off with the machine so you dont have to unplug it. The power supply will also have addition plugs so you can connect other game mods that take 12vdc like LED strips etc.
    Right now we are doing some final testing to make sure we minimize or eliminate any EMI coming from the motor. There is a lot of work involved in a project like this, it is not simply just a circuit board with a few transistors and capacitors. There is even an extensive amount of computer coding involved in a microcontroller. We want to make sure the kit is completely safe to install, after all they will be in all of the machines in our own collection and we know how expensive it is to replace a pinball power board or MPU! There will also be a thumb screw adjustment where you can adjust the motor speed by hand in the 25%-100% range so you can get the perfect amount of desired shake.
    Look for more announcements in the next few weeks along with photos/video. We will be finalizing the price point but it is looking like it will be in the $175-$225 range for the entire kit which includes the motor, motor bracket, plastic shield, driver board, power supply, wire harness and mounting hardware. We will also be interested in beta testers, PM me for more information on that if you are interested. The plan is to call it the "Pinshakers Universal Shaker Motor Kit".
    Thanks,
    Robert Goebel
    Pinshakers
    #26 1 year ago
    Quoted from robgo777:
    Thanks,
    Robert Goebel
    Pinshakers
    One question for ya. Does the flashers trigger the shaker motor when in attract mode? Hopefully not.
    #27 1 year ago
    Yes they would, unless you somehow are able to link into the game code we do not believe there is any way around that. Most of the time though it is just the controlled lamps that flash in attract mode.
    My Champion Pub however does a short flasher sequence after the game ends. During this time the motor would shake when the flasher goes off. It isn't as bad though as you would think.
    In theory it would be possible to prevent it from happening if we were to know the exact sequence and frequency the flashers go off in attract mode. We could then set the program to recognize this and disable the motor until you started a new game.
    We will continue to look for ways to improve the code and the overall kit. A lot of money and resources have been poured into this project already so we are definitely here for the long run.
    Regards,
    Robert Goebel
    Pinshakers
    #28 1 year ago
    Interesting. For pre DMD, instead of being a slave to something you have no control over (light shows) or even worse something that's used a lot like a flasher, what about optos.... existing or adding? What about making use of leaf switches? I have a Funhouse I wouldnt mind adding a shaker to if the shaker could actually make sense.
    #29 1 year ago
    Regards,
    Robert Goebel
    Pinshakers
    Or you could cut power if the switch for the last ball in the ball trough is triggered. You already have a logic board, so not much more work.
    #30 1 year ago
    I have the pinbits shaker in my AFM. I am thinking of selling the game, if I did then I could sell the shaker separately if someone was interested.
    #31 1 year ago
    We are exploring ways to link into the switch matrix. Only thing is it would require a completely different driver board than one that is triggered off of flashlamps or solenoids. If we manage to successfully develop a board that can be tied into the switch matrix then we will likely offer it as a separate kit.
    Thank you for your input and suggestions.
    Rob
    #32 1 year ago
    Quoted from vireland:
    This is an interesting idea and we will look into it further.
    Thanks for the suggestion.
    Rob
    3 weeks later
    #33 1 year ago
    Have a feeling i not going to just buy one of these.
    $ 139.00
    Sparky Pinball
    $ 60.00
    Docquest Pinball Mods
    Various Novelties
    GC Pinball
    $ 29.95
    $ 48.00
    $ 19.50
    Apparel - Unisex
    ArcadeMade
    Various Novelties
    GC Pinball
    $ 499.00
    Id Rather Play Pinball
    $ 75.00
    pinballmod
    Apparel - Unisex
    Pinball Wheezer
    $ 139.00
    Sparky Pinball
    $ 29.95
    $ 13.00
    $ 28.25
    The MOD Couple
    DevilsMuse Arcade
    Hardware
    $ 29.99
    $ 79.00
    Pixels Arcade Games
    £ 49.00
    PinballToys
    Filament Printing
