New! Dark mode!
(Topic ID: 156362)
Who Dunnit? - Need help with slot reel please!
By Willy39
  • 6 posts
  • 3 Pinsiders participating
  • Latest reply 4 years ago by freezie
#1 4 years ago
Hello,
I have a Who Dunnit? and the right reel on the slot machine. Seems slow and does not stop at the intended picture. I think the reel needs to be re-adjusted or tightened on the motor arm? I did do a test in the menu and the opto is working and the reel does spin. It just seems that the right reel is slower. Any help or advice would be greatly appreciated on how I can tighten the right reel so it spins correctly with the motor arm.
#3 4 years ago
Quoted from Willy39:
First things first, DO NOT over tighten that slot...known area of issues because it's made of plastic and will crack.
Moving slowly could be the motor needs to be cleaned. Metal shavings get jammed up inside of it, so do a search for that.
I would deal with that first and that might clear up the wrong picture thing...the reels/stickers have a slot (ha) in them that tells the opto where it is on the wheel...so unlikely you'd have to take off the sticker.
Hmm...did PPS start making new reels?
#5 4 years ago
there are some thread explaining how to work on the wheels and how to grind a flat spot on the motor shaft to avoid further damage .Find those , theres a wealth of info on them .
#6 4 years ago
I forgot about this vid , they cover it in here .
$ 50.00
$ 54.99
$ 350.00
Pinball Basement
$ 11.00
