Anyone have this issue?
When a ball is shot up the upper left taxi lane.... the ball gets stuck under the plastic ramp for about 4 seconds until I think the game tries to find a missing ball & the ramp raises.
Quoted from scampcamp:Anyone have this issue?
You have a switch not working somewhere. Do a switch test with a ball.
Quoted from dsuperbee:You have a switch not working somewhere. Do a switch test with a ball.
Switch #18 tested good not connected in continuity test but when put back in game it doesn't test closed when ball is rolled over or manually pressed in switch edge test.
I don't see part number for #18 in column.
20210602_005948 (resized).jpg20210602_005955 (resized).jpg20210602_010005 (resized).jpgScreenshot_20210602-005822_Gallery (resized).jpgI had a similar problem with my W?D. Switch adjustments needed most likely. Roll the ball over the switch. Make sure it triggers the switch from the inside, center and outside of the orbit. The switch can test as good but if the ball isn’t physically lowering it enough, you will have the problem.
This page was printed from https://pinside.com/pinball/forum/topic/who-dunnit-ball-gets-stuck-under-ramp and we tried optimising it for printing. Some page elements may have been deliberately hidden.
